Compression test results from my Evo 9
Old Jun 11, 2013 | 01:42 PM
mrm95's Avatar
Well I had a compression test done on my Evo 9 with 86k miles this past weekend and cylinders 3 and 4 were only at 100 and 70. Cylinders 1 and 2 were fine. Could this be because of the head gasket being that they are adjacent. And being that I live in Phoenix, AZ its very hot during this time of year so is it possible that I burnt up the valves by running 91 oct and driving in this 105+ degree weather as well? Thanks
Old Jun 11, 2013 | 05:11 PM
barneyb's Avatar
Heat and 91 octane no, blown head gasket between cylinders is possible.
Old Jun 11, 2013 | 05:25 PM
whitersevo's Avatar
Did u add oil to see if compression goes up? U need to do a leak down test.
Old Jun 11, 2013 | 05:36 PM
joseph143's Avatar
did you put the car on a charger when you did the test... also a leakdown would identify any issue that may exist.. a cap full of oil or two will tell you if its the rings...
Old Jun 12, 2013 | 02:33 AM
mrm95's Avatar
It doesn't smoke, knock or anything like that so in that case i'm hoping its not the block.
Old Jun 12, 2013 | 07:03 AM
VWJETTY's Avatar
agree with this
Old Jun 12, 2013 | 10:25 AM
RSGuy's Avatar
Check your oil for coolant
Old Jun 12, 2013 | 10:35 AM
whitersevo's Avatar
This does not matter in your case.. U have uneven compression with one cylinder showing very poor results, its only a matter of time before it shows its face.
Old Jun 12, 2013 | 07:07 PM
Hitmachine101's Avatar
yup leak down test time, try the 2 caps full of oil first to see if the test results raise
sounds like a blown head gasket to me, had a talon with similar results on 2 and 3 cylinders, the head decided to warp on me ( PO got it pretty hot)
got it re decked, new head gasket and fresh headstuds and great compression across the board minus a 10% loss on cylinder 4 -- lol that motor always burned just a bit of oil -- heck it ran after all the work and pulled fine under boost ,, I considered it a win
good luck
just a question for everyone ( not to thread jack or anything ) what should the evo 8/9 compression numbers be ?
Old Jun 12, 2013 | 07:31 PM
itsuishi's Avatar
I'd listen to the guys above.. prevention is better than cure is the saying.... so before things get too bad take the necessary steps to fully investigate and repair now
Old Jun 13, 2013 | 03:22 AM
mrm95's Avatar
good luck
Really good question lol. I just know mine were no where close...
Old Jun 14, 2013 | 12:25 PM
timv's Avatar
91oct and az heat is all you can do sometimes when you live here and aren't converted to e85. Unless you have more than one car. Just try to stay out of boost....
Old Jun 14, 2013 | 02:38 PM
good luck
did some searching on the compression numbers at warm operating level
fresh rebuild or new motor -- 163psi
can go all the way down to 138 psi ( mitsubishi service still considers this a healthy motor )
no more then 14psi difference from cylinder to cylinder
now all of this depends where your at as well, if your well well above sea level then your numbers are gonna be different then someone at sea level
Old Jun 14, 2013 | 02:48 PM
ProPilot04's Avatar
It will have much more to do with density altitude than pressure altitude. That's also why Mitsubishi and other manufacturers have such a wide range for "healthy".
Old Jun 14, 2013 | 05:29 PM
J_Striker's Avatar
Leakdown test. Find out what is the problem before you make the plan to fix it.
