Evo 9 Head convert onto Evo 5. Pls Advise
Old Jun 30, 2013 | 01:01 AM
jameswwt's Avatar
Hi Guys,
planning to swap my Evo 5 head with Evo 9 and what do i need to make it possible?
1) Evo 9 complete wire harness
2) Evo 9 ecu
Is it possible to run the Evo 9 head on Evo 5 engine without the Evo 9 wire harness as the Mivec can be control by an independent Mivec Controller?
Is it possible?
Will very much appreciate if i could used back my Evo 5 wire harness.
Is Evo 9 & Evo 5 block the same?
Please kindly advise.
Thank you.
Old Jun 30, 2013 | 10:15 AM
94AWDcoupe's Avatar
blocks are same. except oil feed to mivec. the oil pressure switch on evo 5 in on back of block under intake manifold. on evo 9 that switch is moved to oil filter bracket. the hole on block is used to feed mivec.
it would be very difficult to control mivec without using the factory 9 harness and ecu. easiest path is factory parts.
a few on this forum have made the conversion on the evo 8. they all used factory 9 parts.
Old Jun 30, 2013 | 11:32 AM
jameswwt's Avatar
Thank you 94AWD,
I think i'll just go for 2.3L built than. maybe its about the same cost as converting to Mivec.
Old Jun 30, 2013 | 11:57 AM
jameswwt's Avatar
Hi Guys, i'll be using back my BC I beam rods on my 2.3L build and what do you guys thinks about matching with Manley 86mm pistons 8.5.1 comp?
Is Manley reliable?
Lastly what head gasket thickness should i go for?
Old Jun 30, 2013 | 12:40 PM
94AWDcoupe's Avatar
all aftermarket pistons are good. its the builder that creates success or failure,
Old Jul 1, 2013 | 11:23 AM
jameswwt's Avatar
ProPilot04
Sep 30, 2019 08:16 AM
jameswwt
Feb 15, 2016 05:59 AM
Erik@MIL.SPEC
Jul 22, 2015 09:39 PM
Erik@MIL.SPEC
For Sale - Part Outs
Jul 20, 2015 01:09 AM
rsonistxl
Aug 5, 2013 04:56 PM
