modifying stock engine mounts
Old Jul 25, 2013 | 01:55 PM
Czarcasm's Avatar
Is there any mod out there that I could fab up to stiffen my stock mounts? 3 of them are off now (clutch change) so I figured id make them stiffer. Anybody? And no I dont want to invest into aftermarket mounts yet
Old Jul 25, 2013 | 01:58 PM
heel2toe's Avatar
Although I have never personally done this I've heard about people drilling holes in the rubber and injecting silicone specifically the silicone used to seal up a windshield to stiffen them up. Search around as apparently its an old DSMer trick.
Old Jul 25, 2013 | 02:30 PM
sujinX's Avatar
press out the stock bushings and press in stiffer ones.
torque solutions sells these. dont know if u have the time to wait, but if u do.
Old Jul 25, 2013 | 04:34 PM
EvoTurboTurk's Avatar
Ralliart is rubber compound & stronger then oem, enough for high hp applications & with a slight increase in vibration inside. Don't get polyurethane that will be awful with the harsh vibration & effects the cv joints, etc!
Old Jul 27, 2013 | 07:20 AM
Fast_Freddie's Avatar
Veteran: Navy
I drilled holes in mine and filled with liquid urethane from McMaster Carr... they have held up pretty well for 2 years now...
Old Jul 28, 2013 | 04:14 PM
Czarcasm's Avatar
Thanks for the input everyone
iatmapotcmst
Jan 28, 2016 02:25 PM
floating doc
Oct 20, 2015 09:45 AM
357
Apr 22, 2015 04:07 PM
XstormtrooperX
Jun 1, 2011 02:50 AM
Tractionlimit
Jul 10, 2009 11:00 AM
