2nd gear stick
Old Feb 23, 2004 | 05:40 PM
Shahul X's Avatar
2nd gear stick
when Im trying to launch somtimes (alot of times).... I cannot get into 2nd gear easily..... gotta let the revs die a bit... whats going on?
I have ss clutch line, did the clutch restrictor mod, stage 3 CM clutch..... perrin short shifter....
-shahul
Old Feb 23, 2004 | 09:58 PM
KFive's Avatar
I'd make sure when your speed shifting to 2nd your getting that clutch pedal engaged enough. Also if you don't have the metal shifter bushings, I hear they work wonders on your shifts. Solid.-
Old Feb 23, 2004 | 10:04 PM
Hungbee112's Avatar
My second gear sticks occasionally when I'm driving slow at lower rpm's, the total opposite. Especially on a cold morning.
Old Feb 24, 2004 | 03:18 AM
Dubai_EvoVII's Avatar
I think that's something normal in the Evo.. It's been happening for my car for 2 years now
Old Feb 24, 2004 | 03:46 AM
simevo's Avatar
Mine used to do that and I used to miss shift into 2nd because of it.
But after replacing the tranny and all gear oil with synthetic, I have no problem shifting into 2nd gear at around 7K to 7.5K rpm.
Old Feb 24, 2004 | 07:52 AM
Shahul X's Avatar
replacing the tranny oil eh.... what exactly did you use?
also...what metal bushings?
-shahul
Old Feb 24, 2004 | 08:41 AM
raywong's Avatar
I had difficulty to shift from 1st to 2nd at high rpm. Changed to Redline MT-90(from HKS gear oil), the problem slightly improved, half of the times shift was good. This improvement only lasted 2-3 months, now I have difficulty not only 1-2, 2-3 was bad too. Just put in Motul 75w90 GL-4,GL-5 today, will try some launch tomorrow.
Old Feb 24, 2004 | 08:48 AM
raywong's Avatar
people in the UK forum are saying good things about Royal Purple gear oil. I personally think the problem is the worn out syncros, changing oil can only help so much.
Old Feb 24, 2004 | 01:16 PM
rizalhoo's Avatar
yup, agree on the worn out syncros.
anyhow i have the same problem too, just finish my 5th gear grinding problem and now have difficulties in shifting to gear 1-2, even to gear 1 is SSSOOOO Difficult, sometimes I have to make a complete stop and then be able to shift it gear 1
Old Feb 24, 2004 | 01:21 PM
USP45's Avatar
Getting into 2nd is difficult for me at times as well. It just does not want to do it a high RPM's, and this is not speed shifting, it is just a normal shift into 2nd.
Old Feb 24, 2004 | 01:25 PM
CidE's Avatar
I dont have any problems with second except for when the car is cold it doesnt go in to well but once its warm no problems. my 4th gear crunches at high rpm though, gonna change the fluid and see if that helps.
Old Feb 24, 2004 | 07:28 PM
Shahul X's Avatar
please let me know how that MOTUL oil works
-shahul
Old Feb 24, 2004 | 08:20 PM
dsm95hybrid's Avatar
You wouldn't thing you would be having worn syncro issues this early, but then again I don't know how you drive it. DSMr's have been adding GM Syncromesh for years. BG Syncroshift is good also. RRE usually has this stuff.
Old Feb 24, 2004 | 08:22 PM
I used to use MOTUL lubricants for my '02 GSXR 750. It's good stuff. Never used in in cars though.
Old Feb 24, 2004 | 08:31 PM
boostedwrx's Avatar
change your shifter cable bushings ASAP!!
I swear, my second gear really, really sucked. I put some of the brass bushings in and lemme just say WOW. Second gear pops in at any rpm now.
