thrust bearings
Old Aug 2, 2013 | 04:50 AM
EvO8_BT's Avatar
thrust bearings
i have a newly built engine by a local machine shop and now everytime i keep burning up the left thrust bearing. it seems like there is too much force coming from the transmission. I have unplugged the pressure switch on the clutch pedal so i know thats not the cause. any help would be great
Old Aug 2, 2013 | 05:56 AM
SDevo13's Avatar
Do you have a pull or push style clutch?
Old Aug 2, 2013 | 10:43 AM
EvO8_BT's Avatar
this is on initial start up and its a pull type. exedy twin...... the thing is that this clutch was installed prior to the build with no issues. could it be an install issue and we have to pull the tranny off again?
Old Aug 2, 2013 | 10:56 AM
SDevo13's Avatar
If its on the first start, you probably have a scored crank or improper installation. In which case you would need a new crank if the damage is bad enough.
***this is in my opinion I am in no means an expert engine builder***
I would talk to a shop who builds a lot of these motors - MAP/Buschur/AMS/ETC
Edit- It could also be from improper (read not enough) lubrication before starting the motor for the first time.
How many times has it happened?
Old Aug 2, 2013 | 11:47 AM
EvO8_BT's Avatar
2 times the crank is still good, we made sure the engine is lubricated, I am going to have to send this off to map or something because I'm done with the head aches.
Piro Fyre
Aug 16, 2015 06:54 AM
foxbat
Apr 27, 2015 09:58 AM
V12KiLLa
10
Aug 11, 2014 10:12 AM
quiquepr69
Jan 16, 2012 07:55 AM
Robertv34
24
Sep 7, 2011 07:23 AM
