Boost drop
Old Feb 25, 2004 | 09:06 AM
SSKILLA's Avatar
Boost drop
i have a quick question for you guys......i have a evo with intake turb back and boost controler ......becfore my boost would hold at 20 lbs strong till red line.......now i installed the super afc2 and it drops 2lbs before red line......i dont understand this too well......i have no boost leaks nothing .....can some one help me out on this.....im not sure how this throttle voltage adjustment can afect the boost ......can some one give me a explanation and if this might be my problem.....
Old Feb 25, 2004 | 09:15 AM
sneaky8's Avatar
thats a good question...after getting my boost controller installed and the afc which was like two weeks ago...im still playin with the controllers to get to that perfect settings!
Old Feb 25, 2004 | 09:23 AM
SSKILLA's Avatar
i mean the throttle settings are put correctly....and all of a sudden its dropping boost now...if it was a fmic hose wouldnt it have blown out by now????...i have no clue what going on....
Old Feb 25, 2004 | 09:35 AM
992gnt's Avatar
Is it warmer now than before you put the afc in? If you have a manual boost controller, they can be affected slightly by temperature. The afc should have no impact on boost whatsoever unless it's hooked to the wrong ecu wires.
Old Feb 25, 2004 | 12:47 PM
SSKILLA's Avatar
i have the greddy profec - B the first one
