HKS down pipe,,, does it need to be wraped?
Old Feb 26, 2004 | 04:23 PM
MYEVOVIII's Avatar
Old Feb 26, 2004 | 04:30 PM
MYEVOVIII's Avatar
Old Feb 26, 2004 | 04:51 PM
Evo Ate's Avatar
The picture that they show with the flex section is from another car....they just use that as a demo to show.
Old Feb 26, 2004 | 08:01 PM
silverEVO8's Avatar
Originally posted by somebody
Okay to all that where worried about water rusting you HKS downpipe I just pulled my Evo up on ramps after driving 30 minutes in the snow and slush and guess what my downpipe is dry. No soaked in water or ice or anything. I would wrap it, not only will it keep you oil temps cooler but also will help with the thermal dynamics of you exhaust system.
Hey man, how do you like the wrapping? Does it seem to help performance wise? I did not ask George to wrap my downpipe. I'm still waiting for my car I sure wish it was finished....
Old Feb 26, 2004 | 08:30 PM
feldguy's Avatar
I've heard of serious problems occuring with thin-walled stainless and titanium headers on American cars regarding heat-wrapping the exhaust manifolds. All the heat contained in the heat wrap helps underhood temps, however does not let the heat radiate from the pipes causing an inevitable breakdown. Makes sense, but I dont know if it will happen on the Evo.
Old Feb 27, 2004 | 09:01 AM
silvrevo's Avatar
So can someone answer the question of the size?
Is it 2.5" 2.65" or 2.75"
Or does HKS have all 3 different sizes?
thanks again
Old Feb 27, 2004 | 09:28 AM
SoR's Avatar
SoR
From the HKS website it's a bit over 2.5" (65mm)
http://www.hksusa.com/products/?id=661
However people are contradicting just like you say 2.65" and 2.75".
Does anyone have a picture that clearly shows HKS DP size?
Old Feb 27, 2004 | 10:36 AM
evo542's Avatar
Originally posted by Jadiem
i have the HKS 3" DP and the only problem i have is the small rattle when i take off..
there's no 3in HKS downpipe, they only make 2.5 (from vivdracing.com
Old Feb 27, 2004 | 10:39 AM
SoR's Avatar
SoR
Originally posted by evo542
there's no 3in HKS downpipe, they only make 2.75
And that is also questionable because HKS website says it's 2.5" and the part numbers of every vendor so far was the same but they claimed different sizes.
Only pictures with a meter would prove it's bigger than 2.5"
Old Feb 27, 2004 | 10:43 AM
evo542's Avatar
the vendors probably measured the whole diameter including the outside
Old Feb 27, 2004 | 10:57 AM
silvrevo's Avatar
Ya, I just ordered mine now.... Went to the HKS web site,, then to a conversion site
HKS Dp is 65mm.... converted to inches it is 2.55"
These vendors need to get there shiet straight!!
Also one said it didnt come with gaskets,,,, and the other said it does,,, I had them double check and he said it does come with them....Anyways Im not going to wrap it , just install it and go,,, should not have any problems I hope.
Thanks again everyone!!!!
Old Mar 9, 2004 | 11:28 AM
silvrevo's Avatar
Well I just got my HKS Dp put on today, and ya I can tell a difference in power. It seems to pull sooner, longer and harder, great mod!!!!!!
And I didnt have it wrpped, just installed and I was off.
Cant wait to put a few more miles on this thing, it iscoming together very nicely!!!!!!!
Old Mar 11, 2004 | 07:40 AM
snoop's Avatar
How much did you pay for the HKS DP?
Old Mar 11, 2004 | 08:34 AM
mikesevo8's Avatar
I just received my HKS DP yesterday.
To answer the size question, I broke out the calipers and measured. All measurements are in decimal inches.
I found the external diameter to be 2.55".
I measured at both ends of the pipe and several places in the middle.
It is the same all along the pipe; very uniform.
The inside diameter, measured at both ends, was 2.45".
This tells me we are dealing with a .050" wall thickness, which sounds right.
So it looks like HKS was correct - 65mm is the right size.
The hole in the gasket that came with it (for the cat connection) measures at 2.625" (2 5/8").
It fits the flat area of the DP flange. I have the UR 3" cat, so not a problem.
Also, the flange bolt holes on the DP and the 3" cat line up OK.
I am glad I bought the HKS, but in hindsight, if you don't care that it's polished,
the Buscher 2.5" is a better deal for price.
I like it polished though.
Old Mar 11, 2004 | 09:42 AM
berkel's Avatar
Hi,
Thanks for info on the ID for the HKS DP.
Did you happen to measure the ID of the stock DP? I know the stock DP is not mandrel bent and has some "flattened" areas for clearance. So, even if it were the same ID as the HKS, the HKS would flow better. Still, I would think the stock DP is a slightly smaller ID.
Thanks,
FB
