HELP to Diagnose Rod Bearings, plz.
Old Sep 22, 2013 | 10:02 PM
Live4Redline's Avatar
Edit... Had an issue that sounded a lot like rod knock but turned out to be a loose flywheel bolt. The two sounded nearly identical.
Old Sep 23, 2013 | 07:10 AM
94AWDcoupe's Avatar
once you get rod knock there is no in chassis quick fix. the cranks are too soft and will never survive a failed bearing. oil pressure loss is most likely reason for failure.
Old Sep 23, 2013 | 09:09 AM
Old Sep 23, 2013 | 01:22 PM
Old Sep 25, 2013 | 02:48 PM
94AWDcoupe's Avatar
yes, it does sound the same. easier fix if crank wasnt ruined from the chatter.
Norske Marcus
Nov 20, 2016 05:49 AM
TiamatRebirthed
30
Aug 20, 2015 06:16 PM
j255c
10
Apr 23, 2012 03:45 AM
JRR
Lancer Troubleshooting
Jun 11, 2011 03:52 PM
mandy1
15
Aug 17, 2010 09:20 PM
