Evo IX Studdering
Evo IX Studdering
For lack of a better word whenever the car is in wide open throttle there is a slight delay followed by a jump up of around 5-600 rpms then a jump down 100 rpms then a steady climb of the engine. I tried changing the spark plugs thinking that was the issue, it made it less intense but the issue still persists. I'm doubtful of boost leak, but I can't figure out what it might be. Any info would be very appreciated.
Info on the car its mostly stock with an intake and exhaust as the engine mods.
If you're not tuned yet then I'd highly recommend getting tuned. Regardless if you go through remote tuner like me or a shop, I'd recommend getting a wideband, 4 bar map sensor and a tactrix cable and learn to log so you can see what's going on. I think all car enthusiast should log!
to the point about boost cut...I vividly remember tuning boost (before I knew there was a load limit enabled fuel cut), and what it felt like when I finally hit it. My god I thought I blew up the engine!
I about smacked my face on the steering wheel.
to the OP, if it's a violent shake/jolt...it sounds like boost cut is your issue, if it's softer and the car just pulls less, it's probably missfires or pulling timing because of some knock.
I about smacked my face on the steering wheel. to the OP, if it's a violent shake/jolt...it sounds like boost cut is your issue, if it's softer and the car just pulls less, it's probably missfires or pulling timing because of some knock.
Interesting, thanks for all the advice so far check on all of that tomorrow, any chance it could be the clutch slipping? The problem's getting worse as well, happening in all gears and not only in WOT, hopefully one of these will be the solution.
►EvolutionX◄
24
Oct 20, 2009 12:27 AM
