1jz owner with Holset need help
Old Dec 16, 2013 | 05:03 AM
Boostage's Avatar
Ok so here is the deal. I'm running an 8 blade wh1c on a stock 1jz. I had a Garrett .63 Single scroll turbine housing machined to fit. on 18psi with a t3 open scroll manifold I was able to make..
Now I would like to convert to Twin Scroll manifold and Turbine housing. I'm hoping to have it come on earlier and breath better up top. My question is.. what Twin scroll Cm2 housing is equivalent to my open scroll .63? It seems i have a few options to choose from here http://www.gillettdiesel.com/DodgeCummins.aspx
Old Dec 16, 2013 | 07:58 AM
Boostage's Avatar
No one knows?
Old Dec 16, 2013 | 05:25 PM
mitsubeastlee's Avatar
Originally Posted by Boostage
No one knows?
9cm2 is equal to .65 a/r that is your best option.
8cm2 = .57 a/r
10cm2 = .73 a/r
Old Dec 17, 2013 | 08:27 AM
Boostage's Avatar
8cm2 = .57 a/r
10cm2 = .73 a/r
Am I correct in assuming that I should stay around the size of my .63 in order to get similar spool? or does that number not mean the same thing when you factor in a twin scroll setup? in other words should I be looking for the sizes you mentioned or bigger?
DDATuned
Apr 25, 2016 11:10 AM
SloEvo12
Mar 28, 2016 02:03 AM
DSPORT
32
Mar 8, 2016 12:56 PM
JohnBradley
Sep 16, 2014 05:20 AM
ETS Michael
Oct 29, 2010 11:10 AM
