Engine Harness modification
Old Jan 19, 2014 | 07:42 PM
galantman03's Avatar
Originally Posted by Fast_Freddie
Good ole ampthenol mil spec connectors... blue ring indicates rear pin extraction
Close! deutsch connectors
Old Jan 20, 2014 | 06:48 AM
ILuvJDM's Avatar
If I ever pull the engine out of the car I will be doing a full tuck.
Old Jan 25, 2014 | 09:50 PM
Lexus01IS's Avatar
I will pay if someone can modify my engine harness. I don't have time to do it myself.
Old Jan 27, 2014 | 02:43 PM
mitsubeastlee's Avatar
I think the best bet is RS harness as evodan stated then just trim the tree down!
Old Jan 27, 2014 | 02:46 PM
EvoDan2004's Avatar
what is it that you want done exactly? what harness are you supplying?
i agree. trim the RS harness and leave it alone from there. if you want that crazy tuck **** then your own. do not count on chase bays to give you what you want.
Old Jan 27, 2014 | 02:50 PM
If I had an evo I'd do it.
Old Jan 28, 2014 | 12:09 PM
jrainwater's Avatar
Well I'm deleting this stuff to save weight but if I can clean it up in the process it's a bonus. Maybe a dissected RS harness is what I need, I just can't find any on eBay. Maybe I will post here for one.
http://pages.ebay.com/motors/link/?nav=item.view&id=281097264688
I'm like 99% sure this is from a RS.
Old Jan 28, 2014 | 01:53 PM
How can you tell? It does kinda look like a thinner harness but I'm not sure.
Old Jan 28, 2014 | 02:43 PM
jason42003's Avatar
I did an abbreviated wire tuck with my stock harness (hid the engine wires behind the intake). It only took me a day to do and that's with depining all the connectors. it turned out alright for a tuck that didn't require me cutting or running wires through the frame, and the car ran smoother afterwards (I'm attributing that to wrapping each wire separately then wrapping each sensor separately before grouping them together and wrapping, I think it cut down on signal interference). The area over the trans right where it comes out of the firewall is still a little messy for my tastes but that's a project for another time.
Old Jan 28, 2014 | 08:36 PM
jrainwater's Avatar
The main engine wire harness doesn't come out of the firewall above the trans btw. It runs along the back side of the firewall from the passenger side where it comes thru the firewall there and when it gets to the driver side it just curves outward at that point. Just a heads up.
Old Jan 28, 2014 | 08:55 PM
jason42003's Avatar
Just shows you how abbreviated the tuck was which gives me hope for cleaning up the squirrels nest above the trans, but like I said another project for another time.
Old Jan 29, 2014 | 09:41 AM
TheBoz's Avatar
Here is all the crap I removed. The 10lbs+ in just wire. I stripped the whole car. Since I have an RS, I don't have power windows, locks, mirrors. So I could removed all that also.
Old Jan 29, 2014 | 01:52 PM
jrainwater's Avatar
Yeah but the mountain dew goes straight to your hips wiping out all weight reduction from the wires.
Old Jan 29, 2014 | 02:51 PM
Lol
Old Feb 4, 2014 | 05:43 PM
Lexus01IS's Avatar
It will be 9 harness complete. I cant use RS harness cause I still have ABS and AC. I want cleaner look and routed neatly.
DSMolition
May 31, 2017 11:33 AM
Aniel
May 11, 2016 09:49 AM
saywhat
Sep 22, 2015 12:47 PM
LOVEMYX
Aug 24, 2015 01:57 PM
jmorris1027
Mar 23, 2013 11:14 AM
