Fresh Build Turns over no start
Old Feb 2, 2014 | 05:52 AM
Biggiesacks's Avatar
I had my cam angle sensor 180 off when i rebuilt. Same situation no start no fuel. Spun that sucker around fired right up.
Old Feb 2, 2014 | 05:57 AM
sr20det91's Avatar
I don't think it's possible to put the cam sensor plate in 180* out.
Definitly possible to install the CAM trigger wheel 180* out and it will cause a no start condition. Also, if your using an evo ecu make sure you have the imobilizer disabled.
Old Feb 2, 2014 | 07:21 AM
Supergoslow's Avatar
Here's the page from the manual in case you don't have it.
Old Feb 2, 2014 | 07:29 AM
evoxsi's Avatar
when i did my build i had a similar problem because i installed the crank sensor backwards. im an idiot..
Old Feb 2, 2014 | 01:14 PM
galantman03's Avatar
thanks for the pics guys, Ill have to check it out when I have time.
Old Feb 2, 2014 | 02:40 PM
its okay i did the same thing, as shows in the pictures I've posted. lol happens to the best of us…
Old Feb 13, 2014 | 02:02 PM
Well i finally got around to checking some things out. Cams sensor plate is correct, as well as the crank sensor.
I'm going to make sure again that the correct wires feed correctly into the ecu.
Old Feb 13, 2014 | 03:23 PM
so I found the problem. the 12v supply to the crank sensor wire was broke, between the connector and the sensor itself, right at the connector side. It had continuity when metered, but when twisted and connected nothing, haha I metered everything else but that thing. eh oh well.
I ended up resoldering right at the connector all 3 wires by depinning the connector itself.
Old Feb 14, 2014 | 11:19 AM
MechTech's Avatar
Glad you found it! Thanks for updating.
Old Feb 14, 2014 | 01:15 PM
1UpMoto's Avatar
make sure the immobilizer is disabled.
Old Feb 22, 2014 | 02:23 PM
So I finally got around to try to fire it up, and it will still not fire. I have fuel, verified by taking plugs out, and I could hear my relays fire for the fuel pumps. I cranked it for about 10 secs, it sounded like it back fired, but it didn't idk if that makes sense. Just to make sure I"m not going crazy or anything, but there isn't a sensor just for ignition right? CAS and CamAS both feed in for injector firing and spark correct? The plugs looked brand new, I think you should be able to tell if they spark by looking at the gap and look for signs of esd basically right? AEM CDI TWIN FIRE btw
Old Feb 23, 2014 | 10:24 PM
3K's Avatar
3K
If your cam sensors not new, try replacing it. Its not that expensive and only takes like 2 min to replace.
My car was down for 5 months, crank no start. I changed the crank sensor, coils, fuel pump, cam sensor support etc... didn't think twice about the cam sensor 'cause the one on the car was only 2 months old. Finally I thought why not just change the cam sensor, I replaced just about everything else.
Changed the cam sensor. The car started on the first try like it never had a problem.
I was so pissed at myself I wanted to kick my own @$$.
Old Feb 24, 2014 | 09:15 AM
J_Striker's Avatar
Disable your fuel pump and see if you can get it to fire with some starting fluid. If you can get it to run for a couple of seconds on the starting fluid, then it's down to fuel pressure and spray pattern. E-85 will flat kill injectors if left in them for awhile....Like when you're rebuilding your engine.
Old Feb 24, 2014 | 09:30 AM
The injectors have been in contact with e85 for 3 weeks now. I think I know whats going on but I have to check it out when I have time. I have 42 psi of pressure btw
Old Feb 28, 2014 | 07:56 PM
Boostin_hard's Avatar
i am having similar issues. looking to see the results for you
