keep or remove Balance Shaft on 2.3L track motor?
The issue is at idle. Only at idle. I am not using Fluidamper- only have 120 miles on the engine, but as of today I am convinced I should use Fluidamper based on 94AWD video posted and feedback.
I hope Fluidamper can help at least a little the vibration at idle.
Mostly, I want it for the long term reliability.
I am evaluating the options of installing the balance shafts again: it seems to be doable with engine-hoist and car on the lift, allowing the whole assembly to be lowered to clear passenger frame rail.
If anybody has experience chime-in or PM
I used OEM delete parts, like Buschur.
I saw that video too. Im seriously considering a fluidampr a bit more now.
2.4, no balance shafts. AMS delete in the front so it still retains the shaft itself but the weights are machined. This way you are not depending on just the little stub shaft to keep the oil pump drive gear aligned. I see a high of 8000-8500 rpm. No issues in 2 years and tons of street, strip, autox and road course racing.
I have stock mounts and the fluidampr.
that's some high rpm for 2.4, how often do you track? I'm more concert about track since this will be mostly a track car, so the engine will spend more time in the upper rpm range.
As far as vibration goes its very minimal to me. I know keeping the stock mounts help. My butt NVH tester approves. I did a recent build for a customer and the vibration I noticed in his car between mine is a noticable difference but not huge. He wanted to keep his balance shafts as it is 99% stock.
jrey2310
33
Mar 4, 2019 11:58 PM
Seancj
Jul 2, 2015 09:07 AM
CORZA
Jun 19, 2015 09:28 AM
