6766 2.0 street car... .63ar?
Old Feb 25, 2014 | 09:01 AM
Mattlws6's Avatar
Running stock motor with supporting mods and kelfords 272s. I am considering my .63 housing while the motor is still stock and putting the larger .86 I have on after I build the motor and need more power. Thoughts?
Car is totally street driven. I don't feel like I am giving up much on the top end, especially on the stock motor. My theory is it will make it much more pleasant to drive and not feel so lazy.
Help with experience is appreciated.
Thank you
Old Feb 25, 2014 | 10:00 AM
EVOjunky's Avatar
It's a 6766. It's going to be laggy no matter what. But yes the smaller housing will help. As for losing top end with it.. your not going to touch the turbos sweet spot with the stock motor so I don't think it will matter.
Old Feb 25, 2014 | 10:02 AM
badev0's Avatar
It will be very lazy either way but the smaller housing should help spool a little bit.
Old Feb 25, 2014 | 10:45 AM
JohnBradley's Avatar
No. You dont buy a big turbo and then choke it with a small housing. You buy the right turbo for the powerband you want and make the best power you can. Small housings on big turbos can make spool worse.
6266 with V band 0.63 if you must but the 0.82 is a better option. The 6766 is pointless until you are past 45psi.
Mattlws6's Avatar
Thank you guys. That's what I was looking for. I will let you know how it does.
roni4g63
Mar 6, 2016 03:29 PM
zanelefko
31
Oct 15, 2013 06:44 AM
B00std4g63
Aug 13, 2012 06:49 AM
Jim in Tucson
11
Apr 26, 2011 05:09 PM
jokerdude1333
35
May 4, 2010 04:36 PM
