??? about 272 cams
Old Mar 5, 2004 | 11:18 AM
Evil_1's Avatar
??? about 272 cams
If a person was to install those. I'm guessing you would need to re adjust your valves clearance right? Has anyone done it them selves? Is it pretty labor intensive? Thanks
Old Mar 5, 2004 | 11:26 AM
masterevo's Avatar
i'm wondering the same too.
Old Mar 5, 2004 | 11:55 AM
maki's Avatar
do you have any experience with timing?
if not, dont touch it
Old Mar 5, 2004 | 04:43 PM
stevEVO8's Avatar
Here ya go! let me know how it turns out.
Install Write up
Old Mar 5, 2004 | 04:47 PM
bishiboy's Avatar
It has lash adjusters, no adjustment needed.
If you keep the belt on the cam gears with zip-ties and keep it on the crank pulley with clips, no timing problems.
Old Mar 5, 2004 | 05:13 PM
stevEVO8's Avatar
I was thinking about doing this but I also wanted to add the cam gears.
If I add the gears also I would have to retime the engine right?
Old Mar 5, 2004 | 05:26 PM
SSKILLA's Avatar
does the ecu need to be retuned with the cams being put in or can a safc do the job
Old Mar 6, 2004 | 01:15 PM
evo542's Avatar
ecu reflash for best results
Old Mar 6, 2004 | 03:25 PM
SSKILLA's Avatar
what changes need to be made to the ECU?
