problem with t4/t3 6262 please..!
i bougth a used 6262 from a friend ... the exhaust housing is a undivided .68 t4 ... i want to know if its better to boy a .63 t3 exhaust housing.. and what would be a dif .. i want 4000 or 5000 rpm spool.. i have a t4 header but i like to know how it will be better on a build 2.0... please HELP
http://www.ebay.com/itm/T3-Countersu...-/141225435371
or can i use this adapter with the t4 Manifold ???
It's a 62mm turbo on what I'm assuming is a 2.0L. It's not going to spool like a stock turbo. You can have a fantastic 5,000-9000rpm wideband however. Don't handicap the potential of a turbo like that by putting a small housing because of spool. If spool is an issue, get a smaller turbo. You want to pick the smallest turbo to do the job....anyway.
so you think that the t4 .68 would do a perfect job ?? i will have a 8,xxx Rpm limit i dont feel going to 9,000 because i would be afraid to blow the engine ! lol
http://www.ebay.com/itm/T4-68A-R-V-band-Turbine-housing-/141027767157?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d5e8f375&vxp=mtr
or
http://www.ebay.com/itm/T4-58A-R-V-band-Turbine-housing-/130959164889?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e7dc645d9&vxp=mtr
in between these 2 housings !!! please HELP HELP !! my Block Is 86.5 mm 9:5:1 Comp ratio !! stock crank !!! .68 or .58 exhaust housing for a 6262 Journal bearing turbo ??
or
if i have 20 psi on 4500 rpm or 5000 rpm ill be good !
You can possibly make more power at high boost. Under 600 I would say no difference between the bigger for power. You have to size for power goal. At 750whp or more the bigger ones will be better.
