head studs?
Old Mar 5, 2004 | 06:51 PM
Seba's Avatar
head studs?
I am getting my 264 jun cams (with spring, retainers and cam gears) installed.
Should I replace my head studs too?
Thank you
Sebastian
Old Mar 5, 2004 | 06:59 PM
en1gma19's Avatar
yes. it makes more sense to go ahead and do it while your already in there. Plus if you mod any further, it's a good safety measure. They aren't very expensive and it's better safe than sorry.
Old Mar 5, 2004 | 07:02 PM
GTVEVO's Avatar
The only answer to that is YES! You have already purchase great parts so you are doing the job right so drop one hundred extra bucks for headstuds it will be worth it even if you don't plan on running more than 19psi on the stock turbo. They are going to be exposed so better now than later. Just my .02
Jun parts are awsome so nice choice I know that you are consious on your selections.
GTVEVO
Old Mar 5, 2004 | 08:10 PM
PPI's Avatar
PPI
For people who have replaced head studs, did you pull the head off or just leave it on and replace one bolt with a stud at a time?
Old Mar 6, 2004 | 06:38 AM
turboDan's Avatar
can be done either way,I did it with head on,1 stud at a time and the best part is that the cams DO NOT have to be removed to do it.See How To's for easy step by step
Old Mar 6, 2004 | 09:08 AM
Mr. WannaEVO's Avatar
With the JUN spring/retainer kit, why dont they sell S/S swirl polished valves with the kit???
Old Mar 6, 2004 | 10:13 AM
memo3's Avatar
You should..
btw, may i ask how much they charge for the installation? cams+head studs? i am assuming even if i only get my head studs installed.. they will still charge me about the same...
Old Mar 6, 2004 | 10:30 AM
Quickshift's Avatar
Re: head studs?
Thank you
Sebastian
If you are gonna install the springs and retainers head is gonna have to comes off anyways. Just make sure the head is bolted down to mitsu torque spec and in the same order, so you dont warp the head.
