Type-H34 BOV for EVO-8??
Old Mar 6, 2004 | 09:00 PM
miubhi's Avatar
Question Type-H34 BOV for EVO-8??
Type-H34 BOV
Is there anyone running this bov , and if so how is your stability.
I have been researching and I seem to like this one for the aggresive sound and not a whistle, but there is not much on the site about likes and dislikes about this one and if i can even use it or not. Even if there is one like this one sounds it could be considered also.
Its the same as the type h i believe but a little more aggressive "right???" I plan to stop upgrading at mid 400's so i want this to last thru the upgradeing stages and be there til the end.
Old Mar 7, 2004 | 05:16 AM
EVOFQ300's Avatar
I have it no problems. You have to bend the fan shroud a little bt to stop it rubbing. Other than that no problems. Holds boost fine and does not flutter. Sounds like stock also
Old Mar 7, 2004 | 09:20 AM
Guru's Avatar
I've installed quite a few. Works perfectly every time (as is expected of Turbo XS products). You don't even need a flange to install. Just put on stock hoses and clamp down.
Old Mar 7, 2004 | 10:16 AM
miubhi's Avatar
great just what i wanted to hear. will be getting one in a few days just ordered the hallman evo rx mbc. can't wait to join the 20lbs and holding club
Old Mar 7, 2004 | 06:48 PM
EVO222's Avatar
I have it and I love it...although is sounds a little soft but its a good buy!
Old Mar 7, 2004 | 06:51 PM
GTVEVO's Avatar
I have this and mine whisltes alittle when the boost falls. It does the job very well I just can't get rid of the damn whistle.
Old Mar 7, 2004 | 08:32 PM
miubhi's Avatar
as long as it hold the 20lbs i will be ok and i will try to defeat the whistle also.
evohang
11
Jan 24, 2013 07:52 AM
shadow1
186
Sep 18, 2011 10:14 AM
merv414
Mar 6, 2009 02:59 PM
HondaFlyBy
Oct 7, 2007 02:36 AM
EVO8904
Oct 2, 2007 04:51 PM
