While I'm in there :)
Old Apr 24, 2014 | 04:59 PM
tsitalon1's Avatar
So here's the deal:
Stock block Evo IX with 103k miles with original head gasket and head bolts.
I plan to change the t-belts, all pulleys, tensioner, seals, and gaskets I can get to.
I'm debating on switching cams. I currently have Kelford 272's and I'm looking to improve spool and top end.
I've heard some S2's might just do that.. Is it worth the hassle of selling my kelfords and buying the GSC'S?
Also, I'm thinking of inserting some head stud's. I know it's the lazy/cheap way out but can I safely just switch out the stud's one at a time? I plan on running 30-35psi on a FP green, are ARP's still adequate or do we need something better now days?
Lastly, I hear one maybe two noisy lifters and might change those as well, what is the preferred lifter to purchase? I know on DSM'S it's the 3g lifters... What is it on an Evo ix?
Here is my current state of tune:
https://www.evolutionm.net/forums/evo-dyno-tuning-results/688267-400whp-fp-green-stock-block-self-tuned-93-a.html?styleid=23
Old Apr 24, 2014 | 05:33 PM
Faisalm's Avatar
Originally Posted by tsitalon1
So here's the deal:
If you're looking for spool you can just play with the Mivec for better spooling. GSC S2s are pretty good. There's a cam test that AMS did a long time ago on an Evo 8 that showed Kelford having the better performance out of many other camshafts
https://www.evolutionm.net/forums/ev...-cam-test.html
I know it may not seem applicable to a Mivec head, but it gives you a rough idea of what you might want.
ARPs are just fine
I believe most of us use OEM lifters but you can still get the GSC zero tick lifters, many people buy those as well, it's really up to you.
Old Apr 24, 2014 | 06:24 PM
slowsrt4:('s Avatar
I would stick with the kelfords, if you had some junk like hks cams, then I would switch.
Old Apr 25, 2014 | 06:15 AM
blackenedwings's Avatar
Exactly. The Kelfords are great cams. Some people prefer the GSCs, but the gain (if any) wouldn't be worth buying/installing new cams and selling the old ones.
From what I've seen, most people run OEM lifters.
Old Apr 25, 2014 | 10:36 AM
tsitalon1's Avatar
Tom posted that he does recommend moving from kelfords to S2's to increase spool and top end... See link to my tune in OP post 24.
Though I would like to see more people agree on that topic before shelling out the cash.
OK, guess I'll go with OEM, or GSC lifters.. Whichever is cheaper.
Old Apr 25, 2014 | 10:41 AM
tsitalon1's Avatar
Originally Posted by Faisalm
ARPs are just fine
Looks like standard ARP's are good to 600hp... I guess that'll work
Now the question of installing them one at a time. I've read the forum is still divided on that topic.
Anyone with first hand horror stories when this was attempted? Of course I would take it one at a time and check torque every step of the way.
Stud's are needed if looking for 30-35psi on a fp green with stock head gasket right?
Old Apr 25, 2014 | 04:01 PM
jrainwater's Avatar
Topline lifters here, they are zero-tick and very affordable.
s240ka24t
Dec 22, 2014 07:15 PM
jeffbeagley
Oct 12, 2014 02:11 PM
Kojimagtrviii
May 24, 2014 06:15 PM
tsitalon1
Apr 15, 2014 08:55 PM
zoso
15
Jan 2, 2011 01:39 AM
