floor harness wiring diagram(LH)
Old Apr 30, 2014 | 09:58 AM
dsmmk4's Avatar
anyone have a wiring diagram for the junction behind kick panel? tracking down and ignition problem( car wont shut off) . replaced ignition switch but still have the issue. need diagrams for plugs C-29-C32 of attached image. thanks!
Old Apr 30, 2014 | 05:37 PM
dsmmk4's Avatar
Can anyone point me in the right direction? I can't find a diagram anywhere!
Old May 1, 2014 | 02:16 PM
dsmmk4's Avatar
Bump!
Old May 2, 2014 | 12:54 PM
jrainwater's Avatar
I have an evo IX so my service manual won't help you. You have an VIII (slightly different wiring) so you should buy this dvd. It's $15 and will be the best investment you could make for your car
http://pages.ebay.com/motors/link/?n...d=200937806749
Old May 2, 2014 | 01:02 PM
06MREvo's Avatar
This thread may help...
https://www.evolutionm.net/forums/ev...s-how-fix.html
Old May 2, 2014 | 08:41 PM
jrainwater's Avatar
That's a great thread but if he doesn't feel like cutting and soldering 100 wires then tracking down the proper wires would probably be easier.
Old May 3, 2014 | 02:26 PM
dsmmk4's Avatar
A great thread it is, but id prefer just to fix the wires I need too. When I grab the harness that goes into the junction and wiggle it I can get the car to turn off. I have my hand on the problem, just can't pin point it. Very aggravating!
Old May 3, 2014 | 03:28 PM
jrainwater's Avatar
If the harness is all clean with no corrosion on it then wouldn't you think maybe the junction box has a short in it? Like the issue is inside of the junction since it works when you wiggle it. That's what I am thinking at least. What are you thinking it is?
Old May 3, 2014 | 05:19 PM
dsmmk4's Avatar
It had some light corrosion I cleaned up. Then packed all the plugs with dielectric grease. I just need to know what color wire is responsible for the ignition function of shutting it off I suppose. Day off tomorrow, going to mess with it some more. Im thinking the corrosion spread through the wire so I'll have to cut it and go from there.
Old May 5, 2014 | 10:49 PM
dsmmk4's Avatar
i think its the green wire with white stripe, on connector c105. can anyone verify this? ive been staring at these wiring diagrams but i keep running myself in circles. "junction block" i suppose is the wrong term, i beleive its reffered to as a joint connector. On top of it all im colorblind, so this doesnt turn into the easiest task hahaha. I think my issue has to lie with what ever wire is linking to the IGN2 functions. Key out of the ignition it continues to run, but also dash lights illuminate. when key is on IGN2 the lights go out as they should. Car starts every time, runs fine. Im so lost, and i really would like to pinpoint the problematic wires instead of cutting and reconnecting all of them. Its hard to beleive that the small amount of corrosion i found is causing all these issues but it has to be.
c900t16
Dec 24, 2020 05:13 PM
miniborg1
Mar 25, 2015 03:59 PM
Gurvir19
Aug 7, 2006 02:53 PM
SALEVO
AEM EMS
May 29, 2006 09:30 PM
NRG
Nov 21, 2003 06:19 AM
