lean before boost
Old May 5, 2014 | 07:24 AM
BlackonBlack2's Avatar
lean before boost
I have a 03 evo 42k
mod's
rev2 map intake manifold
downpipe,exhaust test pipe
evo 9 turbo /stock 10.5 hotside
omni 4 bar map sensor
revolver cams
buschur uicp with stock 9 bov
invidia o2 housing
1100cc fic highz
single pump walbro 255 (mod'd)
The car was running before on 1650cc's and the only thing that changed are:
1100cc injectors high z from low
mod'd fuel pump & fuel sock (oem)
tune, plugs.
In the middle of tuning with Tom. (tscomp)
car runs lean before full boost at 50% throttle or less... (almost like a hesitation before boost)
I've attached a log... any input would be help full.. but the car can also do 100% pull WOT with no issues..??
I made a video of it.. i'll try to upload it on youtube and post a link...
usually doesn't spike to 19a/f usually goes to about 16 before going back to 12's
Possible issues?
Battery?
Fuel pump going out?
Fuel Sock ( which was just changed to a new one)
FPR
couldn't upload it using the attachment...used dropbox
https://www.dropbox.com/s/1nzhffu48p...2_23.38.23.csv
Old May 5, 2014 | 11:43 AM
Bhsj13's Avatar
You really should ask Tom since he is doing the tuning. Im sure he can explain it to you.
Old May 5, 2014 | 03:13 PM
^ we are going back and forth at whats going on with it... I'd thought i'd post it up to see if anyone else had any other inputs on it...
I'm out of ideas on what could be wrong...
Tom's been helpful though the process...
Old May 5, 2014 | 04:48 PM
Bhsj13's Avatar
Cool, im sure you and Tom will figure it out. I wish i had something to help out. let us know how the hunt goes.
Old May 5, 2014 | 05:48 PM
ddxsamx's Avatar
I had the same issue, I tried injectors, o-rings, plugs, fuel pump, fpr, boost leak test all nothing..
It would lean out whenever I attempted to go on boost. I had knocks too though.
Turned out my headgasket was going..
black_out
Aug 2, 2014 05:28 PM
tsitalon1
Apr 8, 2014 06:03 AM
tsitalon1
Feb 22, 2014 07:23 PM
sean89
Sep 27, 2013 11:04 AM
goofygrin
86
Aug 6, 2013 08:09 AM
