Intake Manifold & TB options
Old May 19, 2014 | 08:15 AM
foxbat's Avatar
Got an Evo 5 with 2.3L forged engine, GT3076R turbo, HKS 264 cams. I'm about to tune the car with 27psi boost in mind (93oct). I'm searching for a good aftermarket intake manifold & a throttle body. Since I have a mid-sized turbo, I thought to narrow down my options to mid-sized manifolds. One other factor is that the car is mainly for track use, so I need to maximize the power gain of my setup while minimizing or maintaining acceptable turbo lag level.
The options I'm considering so far:
AMS F1
Magnus V5
JM FAB Race version
Skunk2 Pro Series (although advertised for a stock turbo setup)
Throttle Body:
Skunk2 68mm
Boomba 75mm
I'd appreciate your feedback
Old May 19, 2014 | 08:54 AM
Faisalm's Avatar
AMS F1
Magnus V5
JM FAB Race version
Throttle Body:
Skunk2 68mm
Boomba 75mm
Unless you're planning on porting the Skunk2 STM style, then don't even think about it. Even STM don't recommend it without porting.
Personally I would stick with a stock ported intake manifold + 65mm TB just because the low-mid range would be far more impressive than any IM + TB combination you could think of, except maybe for the HKS Kansai but that would need custom intercooler piping and will end up costing you a lot more.
If you've set your mind with an aftermarket IM + TB, I would go with the AMS F1 with Boomba 75mm, but you'll lose a few horses at the low ~ mid yet gain a noticeable amount up top.
Old May 19, 2014 | 09:12 AM
thepoint4life23's Avatar
Ported stocker. or the stm ported skunk2.
Old May 19, 2014 | 09:15 AM
ILuvJDM's Avatar
I have a MAP Rev2 and Mil.Spec 65mm that both have less than 5k miles on them and both look great. You can check my thread out if interested. If you buy both, I can work with you on price. There are no issues with either part, I just put my car back to stock...
https://www.evolutionm.net/forums/showthread.php?t=691379
John
Old May 19, 2014 | 10:05 PM
rextotherex's Avatar
i would stick with a ported stocker and 65mm throttle body aka ported and re-valved stocker.
remember people run 8's with a ported stock manifold and stock ported throttle body at 65mm. utilize what the evo offers, sometimes spending that extra 1000+ will net you a couple ponies but definitely a loss in spool and street ability.
just my 2 cents
Old May 24, 2014 | 09:37 PM
eckok24's Avatar
Anyone running AMS WITH A 75MM TB?
Old May 30, 2014 | 01:20 PM
I-5 Evo's Avatar
My friend and I run a Magnus V5 and Fullblown TB. No complaints.
Old May 30, 2014 | 11:21 PM
evo7_8u's Avatar
The AMS F1 manifold is a beautiful peice of kit , there's that many manifold's nowdays it's hard to make a decision.
Old May 31, 2014 | 05:06 AM
foxbat's Avatar
I'm convinced that a ported stock mani is probably the best choice for my current setup but I went with the Magnus V5 & Boomba TB simply because I got a very good offer on both. One more reason is that I plan to install a larger turbo in the future.
Old Jun 2, 2014 | 11:59 AM
slowsrt4:('s Avatar
ported stocker FTW, send in the TB to milspec for porting too
Old Jun 2, 2014 | 12:19 PM
mdsevo06's Avatar
With that IM and TB, I would get bigger Cams to wake up that current turbo.
Old Jun 2, 2014 | 01:24 PM
foxbat's Avatar
Absolutely, I'm about to order a set of GSC S2 cams.
Old Jun 2, 2014 | 04:16 PM
jrainwater's Avatar
I'd go cosworth instead personally but gsc makes a hell of a product too.
Old Jun 2, 2014 | 04:26 PM
rmorr791's Avatar
i know curt brown takes a stock manifold and turns it into a 70mm ported manifold. Looks like he has some great results with it if your looking for something different.
Old Jun 2, 2014 | 05:35 PM
jrainwater's Avatar
I went with strictly modified in the Chicago area for my IM and TB porting. Eric did an amazing job. Plus he knows I'm ocd so he spent a ton of time on it lol.
