AYC/ACD delete, make any difference?
Old Jun 17, 2014 | 12:20 PM
Iowa999's Avatar
Originally Posted by broken DSM
How about a shep stage 2 tcase with LSD? Oh. Wait. I forgot that you know more about this than Shep racing. My bad.
What I know about T-cases is secondary to what I know about posting clearly. When you delete something, mentioning whether you replaced it with something else can be useful. Just sayin'.
Old Jun 17, 2014 | 04:10 PM
memphis69's Avatar
rear lsd(USDM) with rearranged plates vs rear ayc(JDM, EDM) - very similar.
ayc much comfortable in dd.
lsd stronger, not so comfortable.
removing ACD make sense only for DRAG car. read: non-acd=subaru
don't break an EVO, buy subaru if you want remove all systems)))
Old Jun 19, 2014 | 04:44 PM
drive955i's Avatar
I had my ACD system removed when I started hearing the whine of death (transfer case gear whine). I had my whole drivetrain reworked by Jon at TRE and had the transfer case internals swapped to an older LSD T-case and had the max-lock rear diff upgrade performed. Keeping in mind that this is MORE expensive than replacing the ACD pump, I am now rid of the pump and it's potential failures, the extra weight over the front end, and I still get plenty of 4wd grip from the upgrades. I track the car at regional HPDE's, but no auto-x (I hear that's where the ACD and AYC really shine) so I don't miss it at all. If you're in your Evo for the long haul and don't plan on selling it later on, going this route can be worth it.
electrasol99
Dec 17, 2024 09:30 PM
BoostNY
Apr 5, 2016 05:23 PM
babaz7
Jun 9, 2013 08:37 AM
rolly1818
Apr 25, 2011 05:43 AM
tephra
Apr 5, 2010 08:02 AM
