clutch replacement without removing t-case
Old Jun 19, 2014 | 12:23 PM
bjmauck's Avatar
Does anyone have a write up on this? I've seen pics of a guy that has done this. any info? I'm working on a 9 with acd if it matters.
Old Jun 19, 2014 | 12:58 PM
bbong's Avatar
I just did this work but I had to split off t-case, dunno how you would do that by not detaching the t-case, though *subscribed* to know how
Old Jun 19, 2014 | 01:11 PM
06MREvo's Avatar
6 bolts holding the t-case to the trans, remove them. Grab a slide hammer & remove the shaft between the trans & t-case. Grab a pry bar & separate the t-case from the trans. Slide the t-case towards the passenger side of the car & let it sit on top of the steering rack/subframe.
Old Jun 19, 2014 | 01:26 PM
bjmauck's Avatar
which side does the shaft come out? how do I attach the slide hammer?
Old Jun 19, 2014 | 01:30 PM
SilverShadow03's Avatar
^Drivers Side
Start at line 26 I believe...
How To
Old Jun 19, 2014 | 05:19 PM
ROB-80E's Avatar
The transfer has to come off to get to bolts holding the gearbox to the engine.
06MREvo posted the process to remove the transfer case above. Removing it is small fry in the grand scheme of replacing a clutch.
Old Jun 19, 2014 | 07:18 PM
TommiM's Avatar
Its not gonna happen on an acd car. There is one bolt holding the block to the trans and the bolt cant be accessed without the transfercase out of the way. Luckily the transfercase comes out pretty easy, and its not all that heavy. This was my secret to doing a clutch job in a garage on jackstands.. http://www.supplementwarehouse.com/v...eHhLmfEmTw_wcB
Old Jun 20, 2014 | 07:35 AM
bjmauck's Avatar
I unbolted the t-case and pulled the shaft out and pried it over and used a ratchet wrench to remove the bolt to the bell housing.
Old Jun 20, 2014 | 08:11 AM
twabtoxer's Avatar
Old Jun 23, 2014 | 05:52 AM
bjmauck's Avatar
You can get the trans out without pulling the tcase. Just unbolt it and push it over to the passenger side. You have to drop the drivers side cradle.
custompaint
Feb 8, 2016 12:17 AM
MrFreddieA
Apr 10, 2015 09:45 AM
tcvernonx
Jun 12, 2014 12:16 PM
Zjcmx
Jun 9, 2014 08:14 PM
