Buschur Racing ethanol content testing, mind blown.
Old Jun 28, 2014 | 07:23 PM
  #46
cfdfireman1's Avatar
And the E85 tester that works by adding H2O only tell tells you what the CH3CH2OH content is, what is the rest? Do we need a flex fuel tester like the Zeitronix to go along with it?
Old Jun 28, 2014 | 07:40 PM
  #47
RazorLab's Avatar
Originally Posted by wrx2evoIX
If you were tuned for 11.5 AFR on E85 and filled with E70 your AFR may increase to low/mid 12's
No, it would go richer with less Ethanol, not leaner.
Old Jun 28, 2014 | 08:06 PM
  #48
That depends on what's replacing the ethanol, no?
Old Jun 28, 2014 | 08:37 PM
  #49
RazorLab's Avatar
Of course, I was assuming gasoline.
Old Jun 29, 2014 | 12:27 AM
  #50
wrx2evoIX's Avatar
Corrected my post to avoid confusion, thanks for those who pointed out the error.
Old Jun 29, 2014 | 02:22 PM
  #51
TheSigmaEnigma's Avatar
I hate how inconsistent Ethanol can be. Here in NY I have to deal with "Winter Blend" and a greatly fluctuating Summer Blend too. Never ends. Thanks for the information tho!
Old Jun 30, 2014 | 08:18 AM
  #52
evotris's Avatar
David,
Don't you think it's still better to test the ethanol content by using the test tube than relying on the ECA?
Old Jun 30, 2014 | 10:04 AM
  #53
David Buschur's Avatar
Originally Posted by evotris
David,
The test tube we sell will tell you what the percentage is so you can be "safe" and know what you are getting.
The ECA from Zeitronix tells you the same thing without the hassle of the tube. The ECA also allows you to wire the input into an ECU and have the ECU change the calibration from pure ethanol to pure gasoline, so there is no worry of timing, fuel and boost needing to be changed at the content changes.
Old Jul 1, 2014 | 08:57 AM
  #54
thepoint4life23's Avatar
I will say i still want one for my car. also a little of topic but how do you guys test it at the gas station, pump it in to a gas can then put it in the tube or what?
Old Jul 1, 2014 | 09:40 AM
  #55
Did you just show us in these videos that the ECA doesn't necessarily show the ethanol content of you fuel?
  #56
egis's Avatar
I always carry small plastic cup.but then again if I see that e85 is a **** I still fuel up cause I have no choice.just try using gas stations with decent e85 which I do.
Old Jul 1, 2014 | 09:57 AM
  #57
Not easy or convenient to test at the gas station but what you said is what you have to do.
tunermt
AEM EMS
16
Dec 13, 2025 01:11 AM
ast
Aug 19, 2025 07:09 PM
jracer
Jun 15, 2016 05:08 PM
TTP Engineering
E85 / Ethanol
Aug 2, 2009 06:14 PM
TTP Engineering
Jul 30, 2009 08:53 PM
