Car not going over 12 psi at wot help!!!!!!
Old Jul 13, 2014 | 09:32 AM
evo9powerr's Avatar
I buy my evo 2 months ago and when i buy it , it has autometer gauges , the autometer boost gauge use to read 18 psi at wor stock i change all gauges to aem didnt use the car since i have another , i buy map 02 dump , buschur downpipe , hks full exhaust and install all those and when i decide to take the car for a ride it feels slow alot and only reading 12 psi on aem boost gauge .. Ive done 2 boost leak test i fix the 2 leaks i have and still 12 psi .. I seen to have a leak on the throtle body shaft seal but i dont think it will put my car at 12 psi by just that leak .. I did change the top vacuun lines i put them all new with the new aem
Boost gauge and i change like 1 vacuun line from J PIpE to the T where is connects with the wastegate vacuun and them goes to boost selenoid , but i use almost the same vacuun and same route .. car dont go over 12 psi ive read like 5-6 threads of people with the same problem and cant find the answer.... Hope anyone can help me thanks
Old Jul 13, 2014 | 09:39 AM
MitsuJDM's Avatar
12psi is about the wastegate pressure. So you may not have a leak. There is either an issue with your MBC connections, or factory boost solenoid connections. Something is causing the wastegate to open at it's factory spring pressure.
Old Jul 13, 2014 | 09:43 AM
RussellDaniel's Avatar
Agreed.
Old Jul 13, 2014 | 11:05 AM
evo9powerr's Avatar
My car has the factory boost selenoid .. is there a way it could get bad???? and the conection is simple .. I dont think nothing on the conection is bad.. Getting a lip frustrated with this issue
Old Jul 13, 2014 | 05:37 PM
evo9powerr's Avatar
Turn out to be that i change my vacuun lines around wastegate and didnt use the boost pills on the new lines .. Thanks all problem solved
98autogstspyder
657
Apr 27, 2022 01:48 PM
jb0evo
19
Mar 22, 2016 10:01 AM
whtjoe
Jul 20, 2015 04:40 PM
Mellon Racing
Evo 'For Sale' Electronics / Lighting / Audio
381
May 24, 2013 05:54 PM
REVOlution X
36
Oct 16, 2012 08:59 PM
