View Poll Results: Which balance shaft kit do you have?
Mitdu OEM stubby
60.00%
aftermarket stubby
0%
AMS race kit
33.33%
GSC race kit
6.67%
Voters: 15. You may not vote on this poll
Poll: Balance shaft removal and mileage input please
Old Jul 13, 2014 | 12:26 PM
nightwalker's Avatar
Looks like this will be my next step, so I was hoping to get a poll of what everyone has and how it's been for them.
Which balance shaft removal kit do you have?
How many miles?
What kind of driving mainly? Daily driver? Track? Drag?
Any failures?
Thanks in advance guys.
*supposed to be Mitsu, not Mitdu.*
Old Jul 13, 2014 | 12:56 PM
mouseIX's Avatar
I would also add if they did a fluiddamper for harmonics when eliminating the shaft. I just installed my engine with an AMS shaft in it. Debating on the harmonic balancer over the stock unit.
Old Jul 13, 2014 | 01:33 PM
xXANCHORMONXx's Avatar
I used gsc with the fluidampr.
My motor was also balance from crank to flywheel.
Smoother than stock imo
Old Jul 13, 2014 | 03:37 PM
^ Good to know. I'll definitely get a fluidampr
Old Jul 13, 2014 | 06:06 PM
TommiM's Avatar
How many miles?
Any failures?
Mitsu stubby shaft
driven about 2-3k miles since the rebuild
Daily drive and Track pretty soon again.
no failures, oil pressures fine
Old Jul 13, 2014 | 07:13 PM
dr_latino999's Avatar
Veteran: Army
- OEM stubby
- 6K so far
- Daily with minimal drag / auto cross, don't get me wrong though, I do like 7500 rpm land
- Nope, nothing wrong but some weird harmonics amplified by my mounts.
With a 2.23L 4G64 and a Fluidampr crank pulley.
Old Jul 13, 2014 | 07:57 PM
okevolutionVIII's Avatar
Machined front shaft, deleted rear, Fluidampr, 18k miles on balanced 2.3L.
Old Jul 14, 2014 | 08:53 AM
AreSTG's Avatar
My OEM motor, with OEM balance shaft spun a balance shaft bearing at about 60k or a little less. Great maintenance it's entire life. Had a couple autox's and drag strip trips at near stock power, rest DD.
Bottom line: they can fail at any power level or use
Old Jul 14, 2014 | 09:04 AM
SmurfZilla's Avatar
2.4 has about 10-15k on the build with the OEM stubby. No issues with oil pressure
Old Jul 16, 2014 | 05:23 PM
Oli170's Avatar
With balance shaft removed, do you feel more vibration around 4k to 5K rpm ?
I removed the balance shafts on my eclipse 95 and I didn't like the feeling, there was a lot of vibration arount 4500 rpm and I felt it from the floor and the pedal.
It is so bad on a evo without balance shaft ? (4G63 or 4G64).
Old Jul 16, 2014 | 05:51 PM
TommiM's Avatar
the only added vibrations are at idle, at least on my car
Old Jul 16, 2014 | 08:40 PM
batty200's Avatar
I have a 2.4 with OEM stubby shaft and just under 10k miles. No issues thus far.
tim85851
34
Oct 29, 2017 05:58 PM
kaj
Sep 6, 2015 10:11 AM
msemaniuk
Sep 10, 2014 05:41 PM
mrg7243
Nov 23, 2011 02:35 PM
Methodical4u
18
Nov 10, 2010 06:32 PM
