Tremendous boost drop?!
Old Jul 29, 2014 | 12:26 PM
Hotsht94's Avatar
Hi guys.
I apologize if there is already a thread on this but anything will help.
I recently changed out my 9.8 hotside with a 10.5 which was a pain in the ***. After getting everything back together and settled in. Went out for a tune,
I wasnt hitting full boost till 4500k. My peak was at 25psi and then drops to 20 at redline. I attempted to turn the boost up but for some reason it didn't budge. Note before I was at 28psi and held all the way.
Any idea what to check or do??
Old Jul 29, 2014 | 02:48 PM
egis's Avatar
what waste gate actuator you have right now?
Old Jul 29, 2014 | 03:47 PM
Terror Rising's Avatar
The 10.5 will spool slower than a 9.8 but definitely not what you're seeing. Are you running a 3-port or an MBC? Did you do a boost leak check?
Old Jul 29, 2014 | 11:34 PM
Hotsht94's Avatar
I have a stock wastegate but I never adjusted it before. I'm running a hallaman mbc, I did a boost/exhaust leak test but it came out good.
Old Jul 30, 2014 | 10:45 AM
slowsrt4:('s Avatar
I can't recall but is the evo 8 wastegate for the 9.8 hotside the same length as the evo 9 wastegate for the 10.5 hotside?
Old Jul 30, 2014 | 11:23 AM
ReaperX's Avatar
^ Yes the wastegate actuators are identical between the 8 & 9 turbo
What is your method of boost control? Is you're wideband reading leaner than before?
If you're boost leak test came back good check for the following:
- Is the wastegate flapper seated properly when closed
- Check for an exhaust leak from mani to turbo
Old Jul 30, 2014 | 11:43 AM
Hotsht94's Avatar
Already checked the hotside/mani/downpipe etc.
no leaks. Gonna attempt to pre load my wastegate and see if that's any help. According to my tuner my AFR's are on spot. I do not have a wideband
Old Jul 31, 2014 | 05:06 AM
way2qik's Avatar
When you start modding a turbo car you need a wideband in the car. Otherwise, you're going to be rebuilding the engine.
6466Animal
Dec 15, 2015 11:32 AM
Odain1
Sep 25, 2015 04:15 AM
sssr20det510
13
Dec 9, 2014 10:39 AM
HFA_Ultima
May 30, 2011 01:32 PM
daisaw1219
Jul 5, 2006 10:27 PM
