ask for cam
Old Mar 12, 2004 | 12:41 AM
teddy's Avatar
ask for cam
hi i just want to install a hks cam for 264in/264ex and did i need to change the valve spring,cam gear and ecu ,becuase i see a lot of people just install the cam only and everything is fine,but some people said if change the cam for 272/272 it need to change a lot of thing to help safety is that true
and one more thing if i just change the fuel pump did it will gain Horsepower .
thanks
Old Mar 12, 2004 | 12:55 PM
evo542's Avatar
you don't need springs for 264 or 272, but I would recommend an ECU reflash
Old Mar 12, 2004 | 01:57 PM
stevEVO8's Avatar
Dude dont change the fuel pump unless you have the supporting mods its not gonna give you any more HP than you have right now.
Spend the money on a boost controller, cams, exhaust and a reflash. Then if you need to add the fuel pump with the cams and flash do it.
GTVEVO's Avatar
You don't have to upgrade the springs but it is a good Idea too. Put it this way it is needed but it isn't a must so it depends on how picky you are personally or your personal opinion. Myself I am going to purchase springs with the cams thus being why I haven't upgraded the cams yet. Remeber the object of the game is to build up a motor that will generate alot of HP but it also has to hold together with any personal doubt so you can use the HP.
