Intercooler
Old Sep 9, 2014 | 01:22 AM
Evv007's Avatar
Intercooler
Hey guys my girlfriends mum accidentally hit me and did no damage other the squashed a section of my intercooler with the tow bar doesn't seem 100% bad but just wanted to know if there will be any problems down the track or should I just get it changed for a new on any info be good! Still getting 21psi boost so hasn't affected power
Old Sep 9, 2014 | 03:57 AM
slowsrt4:('s Avatar
you should do a boost leak test to see if the intercooler is leaking. I know your car is showing 21 psi, but better check it out with an actual boost leak test to make sure it isn't leaking.
Old Sep 9, 2014 | 03:58 PM
egis's Avatar
it all depends if your gf's mum is hot or not.if she is hot then you should be ok with your slightly damaged ic.if shes not hot then you should tell her that ic is badly damaged and you need a new one,like high end new one.just my 2cents.
Old Sep 9, 2014 | 04:14 PM
Faisalm's Avatar
I think I'm using this in my signature
Old Sep 9, 2014 | 06:19 PM
Evv007's Avatar
Inter
So I better get a new one then?
Old Sep 10, 2014 | 08:31 AM
ETS Michael's Avatar
Post up a picture of the damage. We may be able to visual tell depending on the damage.
Michael
Old Sep 11, 2014 | 10:22 AM
Evv007's Avatar
Intercooler
Michael
How do I send the photo across ?
Old Sep 11, 2014 | 11:25 AM
https://imageshack.com/
Old Sep 12, 2014 | 07:48 PM
Evv007's Avatar
Photo of intercooler
Okay guys I finally got the photo up let me know what u guys think
https://imageshack.com/i/hjL2qqVDj
Old Sep 13, 2014 | 04:08 AM
legacydestroyer's Avatar
Do the boost leak test as recommended and see what you got. Personally I would replace it since it has been hit, leaking or not, but that's just me. If you can live with how it looks and it isn't leaking, then roll with it.
Old Sep 13, 2014 | 09:06 AM
TommiM's Avatar
Do a boost leak test, if its not leaking then your good. That damage looks cosmetic. Mine got bumped worse but its not leaking. You will be fine.
Old Sep 14, 2014 | 01:27 PM
Boosted4's Avatar
can we get a picture of the mom for assessment?
Old Sep 15, 2014 | 10:29 AM
I would get a leak test done. Only way to tell. The tubes are smashed pretty good and made out of thin material. The bottom left looks like a hole, but it's hard to tell.
Michael
Old Sep 15, 2014 | 06:56 PM
cwyteboi's Avatar
Off topic.
Has your GF got marriage potential? If not, then charge the mum. If yes, then it's out of your purse. Politics are best here.
Parts of this thread are cracking me up. Couldn't resist. Sorry!
Like Michael said, boost leak test, then go from there.
Old Sep 16, 2014 | 07:07 AM
haka's Avatar
How do you do a leak test on an ic anyways? I always see crazy makeshift pvc things people use. is there an actual tester unit you can buy?
