Forge BOV not holding boost?
Old Oct 25, 2014 | 09:01 AM
D1andonlyantman's Avatar
Hi. When I bought my 9 I was getting really bad cavitation when letting off the throttle. I bought a forge DV (because I had one on my old LCR which worked nicely) and the problem seemed sorted, the recirc was nice a smooth. Recently I've had quite a lot of work done (cams, rods, intake, EBC, turbo elbow, remap) and now when it's building boost I can hear a sort of pulsing fluttery sound. It's more noticeable in the higher gears. The tuner who mapped it said it boosts to 1.8bar and holds at 1.6 on his external boost gauge he uses for accuracy. When he was looking over the car before the work was done he said he noticed the forge DV was on the wrong way. I fitted it and it was working fine but he's a well known tuner so I didn't doubt it. Firstly, is it possible the DV was on the wrong way round which made it harder for the piston to be pushed open, therefore making it hold boost better? Secondly, I've heard of people removing the DV altogether. I'm no professional but I don't see how that's a good idea, but could I block the DV holes and then go for a quick drive and if the noise is gone I know it's the forge DV not holding boost, or would that be bad for the turbo because it couldn't recirc?
Thanks
Old Oct 26, 2014 | 04:50 AM
No one has an opinion?
Old Oct 26, 2014 | 05:29 AM
enjoiskater7788's Avatar
Do a boost leak test you should be able to hear of its dumping boost.
Old Oct 26, 2014 | 05:35 AM
Ok, thanks
El Boricua
10
Mar 29, 2005 05:01 PM
jbrown
16
Nov 30, 2004 08:22 PM
babyburner
Apr 24, 2004 08:47 AM
XRS-Lift
Dec 19, 2003 01:15 PM
