Evo 8
Old Mar 5, 2015 | 04:33 AM
Buonanno's Avatar
Evo 8
My starter relay makes a lot of noise when the key is in the in position and it won't start I keep turning the key and it won't catch it may catch like after 50 times of turning it the starter is new it was under warranty so I just swapped it and all the wires r plugged in on the starter
Old Mar 5, 2015 | 06:05 AM
Bhsj13's Avatar
sounds like a starter mechanical issue. get another one with the warranty.
Old Mar 5, 2015 | 09:21 AM
Buonanno's Avatar
Third starter same problem all tested good
Old Mar 5, 2015 | 10:57 AM
Buonanno's Avatar
It's going Into the shop at 3 any other things it could be before I take it
Old Mar 5, 2015 | 11:05 AM
Ev0ikon's Avatar
If all your starters are fine, relays and sensors (Crank, cams) are good then your timing is off.
