Leakdown/compression Results
Old Mar 25, 2015 | 12:01 PM
car_nut15's Avatar
If it was my car.... The motor is out. Tear it down, measure it out. 25k in 5 years, its clearly your racecar and probably gets driven as such. The leak down is approaching the "meh" zone, although not terrible, so I doubt there is major wear/damage. Re-ring and new bearings is cheap. You can hone the cylinder yourself with a ball hone and electric drill.
As for your blow by, I agree it was probably because of the dipstick vent. I was running STM's vent fitting in the front balance shaft inspection hole, and it filled the catch can in 600 miles. I removed that line and it doesn't even get oil in the catch can now, just condensed crankcase vapor (smelly as *** yellow **** lol)
Thanks for the advice. I guess might as well do it right while the engine is out. Interesting you mentioned the balance shaft fitting because I purchased one in hopes of fixing my problem but I guess that won't work either lol...
John Collison
Jul 19, 2018 01:43 PM
BoostNY
17
Jul 15, 2012 07:21 PM
Jrah2987
Dec 17, 2010 09:19 AM
dhahlen
Jan 14, 2009 07:36 PM
Fast Frank
Jun 28, 2005 05:11 AM
