Evo 8 overheating under load!
Old Apr 1, 2015 | 08:18 PM
Ocho 9's Avatar
OK new info
Did a compression test just for the he'll of it... 160 across all 4 cylinders... So I'm good there.
Just did a pressure test.. Pressure stayed consistent at idle!
I held the idle at 4k for about 5 mins and hit the 2step twice then the pressure rose.... Once I let off the pressure dropped to regular temp in about a monute
Old Apr 2, 2015 | 04:34 AM
Ocho 9's Avatar
No help?
Old Apr 2, 2015 | 07:29 AM
Ev0ikon's Avatar
How old is your thermostat?
Old Apr 2, 2015 | 08:20 AM
Bhsj13's Avatar
sticky thermostat.
Old Apr 2, 2015 | 09:14 AM
Ocho 9's Avatar
Still original thermostat
Ocho 9's Avatar
I'll definitely give that a shot
Old Apr 2, 2015 | 11:42 AM
aceeca's Avatar
I had this same issue with my 92 Toyota Mr2 turbo, and it ended up being a blown head gasket. I know it's not the same motor but figured I'd let you know. Definitely diagnose a bit more first. I replaced my thermostat and radiator cap as well as flushing the fluids. It didn't fix my issue so I replaced the head gasket and everything was normal. Hope yours is less involved
If you have a shop near by, ask if anyone has a combustion leak tester that you can use. If your not familiar with it it'll sniff out exhaust fumes in your coolant. Should be something like this
http://www.amazon.com/gp/aw/d/B000NP...7lL&ref=plSrch
Old Apr 2, 2015 | 12:10 PM
Ev0ikon's Avatar
^This could be true. But if the coolant doesn't look contaminated I would replaced the thermostat first.
Old Apr 2, 2015 | 12:31 PM
Ocho 9's Avatar
Going with the thermostat first.. Cheaper route then I'll go with more involved testing
Old Apr 2, 2015 | 11:06 PM
garystanfield23's Avatar
new thermostat first is the top and bottom of the radiator hot .. if not could be blocked rad . then head gasket and you wont see contamination in the water if it's gone across cyl to water .
Old Apr 3, 2015 | 04:38 PM
Ocho 9's Avatar
Update!!!
So I bought a thermostat and installed it.... I couldn't get an oem cap till Thursday so I bought a mishimotto one.
Installed and drove the car normal and drove it hard. No overheating at all... But with this mishimitto thermostat the car runs A LOT cooler..
Since stock opens at 80 and the mishimoto opens at 66.. Is it safe to run that cool? And should I assume my problem is solved?
P.s. I'm still buying an oem one
Old Apr 3, 2015 | 05:20 PM
meckert's Avatar
going to depend---your whole injection system, from open to closed loop is dependent on water temp--if it doesn't see the engine getting warm enough it wont switch over.. you may not notice it up front. But just so you know---you should have simply dropped the same temp thermos in it so you stop introducing new variables into your issue.
Old Apr 3, 2015 | 05:49 PM
Bhsj13's Avatar
you will be fine. but, i would have gone with what your car is tuned with.
Old Apr 4, 2015 | 09:44 PM
Ocho 9's Avatar
I bought an oem one today.... My car was all over the place and broke up a bit.... I wouldn't recommend the mishimoto thermostat to anyone that has been tuned on an oem one. Rpm was super high and fans only came on when at idle. Thanks for everyone's help!
evolvedevo91
Dec 30, 2014 02:56 PM
blackevolution8
Sep 14, 2011 04:20 AM
razorlab
100
Oct 9, 2008 04:44 PM
bigric09
Sep 4, 2007 09:59 AM
kreionic
Jun 7, 2007 03:13 PM
