help... asap
Old Mar 18, 2004 | 11:53 PM
Evo11V's Avatar
Veteran: Army
Talking help... asap
***I Finnally Found a Solution!***
on the fuel pump housing on the top there is 3 hoses. one of them is to vent the tank. I smelled fuel after a trip and took apart my back seat to get to the fuel pump housing. Well i found the piece for the vent was broken off. Anyone have any ideas of where to get this piece or how to fix this problem? I went to Mitsubishi parts and they told me I would have to replace the whole houseing for like some rediclious amount of money, and they did not carry that once piece.
Someone please help me with some ideas.
Solution:
ok so finnally found a solution for this problem. The dealer wanted like $400 something to replace the whole fuel pump housing, LOL. Yeah that was a joke! So I took a guess at something and purchased a "Lancer" fuel pump housing from a local junk yard. The pump housing is different but, guess what they have a same plastic connectors, and it took a few minutes. The guy at the junk yard was like its not going to work bla bla bla, and sure enough same exact plastic connectors! Wahoo!!! This is great, only cost me $75.00 to buy the whole pump housing which of course I made the guy who installed it pay. Hope this helps someone else!
Old Mar 19, 2004 | 12:03 AM
Evo11V's Avatar
Veteran: Army
Correction the fuel return hose.
Old Mar 19, 2004 | 12:05 AM
pickleknock's Avatar
if its broken, and you didnt break it, then its covered by warranty. so dont let them try to charge you money.
Old Mar 19, 2004 | 12:10 AM
Evo11V's Avatar
Veteran: Army
yeah but i changed the fuel pump a little ways back.... and they can easily say i did it.
Old Mar 19, 2004 | 01:58 AM
Fourdoor's Avatar
Re: help... asap
You put the cover back on, put the seat back in, take it to the dealer and tell them you smell gas in the cabin. If they don't fix it under warrenty I would be shocked!
Keith
PS: That is all assuming you are on the stock fuel pump, if you changed it out they can claim you damaged the assembly.
<edit> read further down. Acctually you probably DID break it! I almost did on mine wrestling with it when I changed out my pump.
Check in local (and on line) junk yards for a wrecked EVO, also post up in the "parts for sale/wanted" forum here on Evolutionm.net.
Old Mar 19, 2004 | 02:05 AM
Fourdoor's Avatar
BTW, with that part broken you are dumping GALLONS of fuel on top of your tank and letting it run onto the ground. Your car is a horrible fire hazzard right now.... and you are probably getting horrible mpg when driving it....
Keith
Old Mar 19, 2004 | 07:43 AM
Evo11V's Avatar
Veteran: Army
yeah your right about that! trying to figure out where to get the part from
Old Mar 19, 2004 | 07:54 AM
rubelcon's Avatar
Just dont go to a dealer, they will tell you that you need to replace the whole car.
Old Mar 19, 2004 | 07:57 AM
Evo11V's Avatar
Veteran: Army
need some ideas of where i can get this part....
Old Mar 19, 2004 | 07:59 AM
rubelcon's Avatar
Try RRE..
Old Mar 19, 2004 | 08:28 AM
jj_008's Avatar
Go to a dealer and order the part. If it is just a crack, remove it and use super glue to fix it.
Old Mar 19, 2004 | 10:45 AM
Evo11V's Avatar
Veteran: Army
RRE?
Old Mar 19, 2004 | 10:49 AM
MalibuJack's Avatar
The reason this thing is so expensive is because the dealer will replace the entire assembly (Pump, filter, housing,level, etc) I don't know that the upper portion or even the skeleton is available seperately.. Definitely try to get the part from a salvage yard.. you may get lucky and find an assembly that has the upgraded walbro pump on it.
Old Mar 19, 2004 | 12:34 PM
Evo11V's Avatar
Veteran: Army
someone must have done the same thing... that nipple is a easy one to break especially in the cold weather.
guess junk yard is the best bet..?
Old Mar 19, 2004 | 01:11 PM
CombatCQB's Avatar
From what I can tell in the manual, the fitting is simply a 90 degree bend to run the fuel back to the tank.
Why not go to Home Depot an look for a brass fitting that you can replace it with. Depending on how badly the fitting is broken, a little dremel work and make a hole to fit the brass fitting. Heck, I think you can just drill a new hole and it should work.
Bryan
