Lining Up Crank Gear
Old Apr 12, 2015 | 10:11 AM
ReivaXVrai2's Avatar
I am rebuilding the engine in my 8, and I'm to the point where I need to put the crank gear back on. Can I just turn the crankshaft a few times to see where TDC for number 1 is, and then put the crank gear on lined up with the mark on the block, or do I need to use a certain tool to find TDC?
Old Apr 12, 2015 | 11:05 AM
b16a95eg's Avatar
As long as your crank trigger wheel is on in the right direction the crank gear can only go on one way. So just rotate it to line up with the timing mark on your front case. Since the engine actually isnt in time yet, since your timing belt is off, you can just line up the crank at TDC then do the rest of the timing.
Just make sure you have the trigger wheel on in the correct direction, or it will be 180* out if I remember right
Old Apr 12, 2015 | 11:12 AM
How can I be sure that it is on in the right direction?
Old Apr 12, 2015 | 05:54 PM
robbyredneck's Avatar
if the mark is showing.
Old Apr 13, 2015 | 10:44 AM
b16a95eg's Avatar
If your trigger plate is used just look at the side that should have the imprint from the crank gear being on it, that'll be the easiest way.
s240
Oct 19, 2015 10:16 PM
heyythurr
Nov 3, 2014 11:52 AM
Evo Guy 86
Dec 12, 2013 01:32 PM
_des_
Mar 8, 2012 07:56 PM
hybrids14
Mar 19, 2007 01:06 PM
