tial bov question
Old Apr 21, 2015 | 06:52 PM
mykep83's Avatar
tial bov question
I've installed my b.o.v.
I have upgraded to a 1/4" i.d. line back to the manifold. And I'm on speed density.
Under 5 lbs I get the compressor surge sound. Anything under half up to w.o.t. anf above 6lbs I'm get the compressor surge and then I guess the normal b.o.v. sound the wuuusssshhhh..
I don't believe this is normal. Thoughts?
mykep83's Avatar
Evo ix mr stock turbo. Ets piping
Old Apr 21, 2015 | 07:42 PM
mykep83's Avatar
tial bov question.
I have an evo ix mr on speed density.
Recently put the b.o.v. on and under 5 lbs of boost I'm getting the compressor surge sound.
Anything over 5 lbs I'm getting the surge then getting basically a pressure dump like other b.o.v.s is this normal?
I did replace the line to the i. Mani to a 1/4" i.d. line
Help I have track friday night lol
I did replace the line with
Old Apr 22, 2015 | 02:56 AM
lostsoulsevo's Avatar
What gear are you doing this in? To much load at low rpms in a higher gear will give the same effect you're describing.
Old Apr 22, 2015 | 03:57 AM
theblackbeast11's Avatar
might have wrong spring in it as well
Old Apr 22, 2015 | 04:55 AM
Boost Demon's Avatar
Veteran: Air Force
Spring rate depends on vacuum at idle. Make sure you don't have any boost leaks and check out the chart at the top of this link:
http://www.tialsport.com/index.php/tech-bov
Old Apr 22, 2015 | 07:59 AM
llDemonll's Avatar
is it actually compressor surge or does it sound like the bov is opening and closing quickly
if it sounds like the BOV, the spring is too stiff
sekula
Oct 7, 2009 04:17 PM
mike1023
Jun 7, 2009 12:25 PM
turboDan
May 8, 2006 01:52 PM
turboDan
Mar 21, 2006 07:26 AM
Dasneak MR
Feb 14, 2006 04:37 PM
