Wet piston top
Wet piston top
I was changing the plugs on my IX MR today and was shining a light down the spark plug holes, noticed the top piston of cylinder 2 was wet while all others are dry...
I'm also having an issue with it smoking at start up, but only for a second or 2.
Just a quick puff, then it's completely gone.
I consume maybe half a quart every 3k+ miles.
Doesn't burn at WOT, idle, decel, etc.
What's up?
What's up?
It most likely is taking account for the oil consumption. But it could also possibly be a leaking injector. So you shut off your engine your still going to have fuel rail pressure and if you've got a bad injector its going to leak past and dribble into your cylinder and mix in with your carbon deposits on your piston making it look/feel oily... Just a thought. How does your engine run? Any issues?
crcain
Apr 29, 2009 12:38 PM
bradc
Feb 28, 2009 02:19 PM
kkarim
Feb 11, 2008 05:40 PM
gofaster87
Jan 8, 2007 03:30 PM
