Springs recommendations wanted.
Old May 25, 2015 | 01:38 PM
ecktt's Avatar
I'm assembling a 4g64 with a BC stroker kit, evo 4 head (basically the same as a 5-6-7-8) and GSC S2 CAMS. When I bought the CAMS, the site said it could used with stock springs for stock Rev rang but needs upgrading springs to rev higher. Since there is little to no info on a stroked 4G64, I have no idea how high I can rev this thing.
Should I upgrade the springs (and retainers)? How high can I rev this combo? What else should I upgrade in the engine?
Old May 25, 2015 | 03:02 PM
CurseDSM's Avatar
There is info on how high you can rev the 4g64 motor. If it is a long rod kit you can do 9000-9500 ish if it is a standard kit up to 8500 or so. If I were you I would being the stock rev limit is only 7200 rpms. If your going to wind out that motor you mine as well upgrade.
Old May 26, 2015 | 05:41 AM
ecktt's Avatar
Its an out of production BC stroker kit with a 106mm stroked crank with rods and pistons setup up for the standard 86.5mm bore and 8.5 compression for the 4g64. I'm not sure if this is long rod, but I remember reading that it was in some thread here. The GSC R2 didn't exist when the S2 were bought. The S2 seem to be cams the respond at higher revs. Hence my interest in how high can this setup be revved, but if not more than stock(7600 RPM), should I stay with the stock springs?
Old May 26, 2015 | 02:36 PM
CurseDSM's Avatar
Ok well in that case then I would get springs. I have s2 cams and they are great, I rev all the way to 9500 if I want to with my current springs. If it were me id upgrade springs just for added insurance and not having a chance to float a valve.
Old May 26, 2015 | 09:45 PM
ecktt's Avatar
Suggestions, brand, model, etc?
Old May 27, 2015 | 01:25 AM
CurseDSM's Avatar
Well I am bias being I work for PSI springs lol I use those but we don't make a 4g spring. So with that said I would say use my competitors springs. Kiggly springs are probably the best springs ( other then ours lol) for our cars. I would use his in a heart beat. Hands down best option for the car.
maperformance
EvoX 'For Sale' Suspension / Brakes / Handling
403
Apr 8, 2014 09:05 AM
xjtwo
Northwest Region
Apr 18, 2012 07:50 AM
scothu
Nov 9, 2010 03:09 AM
DjRiice
Sep 21, 2004 06:08 AM
