Don't know what it is but I WANT ONE!
Old Mar 23, 2004 | 12:08 AM
EvoVIIIFL's Avatar
Okay guys I took out a modded STi tonight and i could care less about the 300hp, yada yada other bull****.. i just want to know what a certain part is and can where i can find it and can it be adjusted to go on our Evo? the guy called it a rev limiter? he set it on the dash tach so that he sets at what rpm he wants to get a warning light with a quick BEEP telling him to shift... I WANT ONE!!! any info would be greatly appreciated! i want the same set up basically on the dash tach so i don't have to get another tach again thank in advance for any info!
Old Mar 23, 2004 | 12:10 AM
petey pab's Avatar
a G-Tech does the same thing. you can mount it on your dash and all you have to do is plug it into your cigarette lighter.
Old Mar 23, 2004 | 10:28 AM
EvoVIIIFL's Avatar
well im lookin out there to see if i can have it set up so it goes IN the dash with the tach so i don't have any loose wires or anything.. thanks for the info i'll check it out though.
Old Mar 23, 2004 | 10:41 AM
blonde's Avatar
the thing you are talking about is built in to the STI dash and it is like that from the factory. there is no way you can make it fit on the EVO. However, look in google for shift light and you should be able to find a shift light that is very small and looks pretty much the same. now all you have to do is mount it on your dash and you are good to go....
Old Mar 23, 2004 | 11:17 AM
Monkey's Avatar
yeah, they make very small shift lights that you can mount to the top of the steering column. just put that in and you can program it to whatever rpm you want it to illuminate at.
Old Mar 23, 2004 | 11:24 AM
Rasputin's Avatar
Re: Don't know what it is but I WANT ONE!
side note: a rev limiter is what you hit when you go a little too far past the redline and hear the engine crank itself back down.
Old Mar 23, 2004 | 01:15 PM
Shahul X's Avatar
search our own vendor sites...they have em
-shahul
Old Mar 23, 2004 | 04:19 PM
HALF BAKED's Avatar
In Timeout
hks turbo timer type 1 has it.
Old Mar 23, 2004 | 05:31 PM
MrBonus's Avatar
http://www.raptorperformance.com/
Check those out. They can also work for a stealth install.
Old Mar 23, 2004 | 07:52 PM
en1gma19's Avatar
Here's another option. It's called the Rev-Lite.
http://www.rev-lite.com/rev.html
Old Mar 25, 2004 | 01:14 AM
Evo442's Avatar
wow.. both look cool
Old Mar 25, 2004 | 04:44 AM
MattGold's Avatar
Or even better, check out the new Sparco ones!
http://sparcousa.com/tuning_lights.asp
Old Mar 29, 2004 | 02:20 PM
mitsuorder's Avatar
wow, I bet the Sparco's are NICE, here is a link to Rev-Lites for $70 http://www.race-sport.net/revlite.html
Old Mar 30, 2004 | 04:27 PM
EvoVIIIFL's Avatar
does anybody out there have these products installed on their Evo? if so could you post a pic please? thanks again for the info guys!
Old Mar 30, 2004 | 04:39 PM
silverEVO8's Avatar
I got my "check engine light" to flash at 7000 rpm.... Makes a great shift light
