NHSTA findings on clutch, 5th sync,wing,vac lines
Old Mar 24, 2004 | 06:22 PM
TDC's Avatar
TDC
In Timeout
http://www-odi.nhtsa.dot.gov/cars/pr...sb/results.cfm
Why are peeps still getting stuck with clutch bills???
Make : MITSUBISHI Model : LANCER Year : 2003
Service Bulletin Num : 0322001 Date of Bulletin: NOV 01, 2003
NHTSA Item Number: 10005282
Component: POWER TRAIN:MANUAL TRANSMISSION
Summary:
NEWLY CONFIGURED 5TH GEAR SYNCHRONIZER SLEEVE FOR 2003 LANCER EVOLUTION MANUAL TRANSMISSION. *PH
Check to Request Research. Submit below.
Service Bulletin Num : 0323006 Date of Bulletin: OCT 01, 2003
NHTSA Item Number: 10004448
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:TORQUE CONVERTER
Summary:
TORQUE CONVERTER SHUDDER, SURGE, AND/OR VIBRATION (POSSIBLY INTERMITTENT) WHEN DRIVING 35-50 MPH AT STEADY THROTTLE. *TT
Service Bulletin Num : 0355008 Date of Bulletin: OCT 01, 2003
NHTSA Item Number: 10004454
Component: VISIBILITYEFROSTER/DEFOGGER SYSTEM:WINDSHIELD:BLOWER
Summary:
DEBRIS (SUCH AS LEAVES, ETC) ENTERING THE FRONT COWL AREA MAY CLOG THE EVAPORATOR HOUSING DRAIN TUBE. IF THIS OCCURS, THE EVAPORATOR HOUSING MAY FILL UP WITH CONDENSATION AND OVERFLOW INTO THE PASSENGER COMPARTMENT, AND INTO THE BLOWER MOTOR THROUGH THE COOLING TUBE. *TT
Service Bulletin Num : 0355008R Date of Bulletin: OCT 01, 2003
NHTSA Item Number: 10004455
Summary:
DEBRIS (SUCH AS LEAVES, ETC.) ENTERING THE FRONT COWL AREA MAY CLOG THE EVAPORATOR HOUSING DRAIN TUBE. IF THIS OCCURS, THE EVAPORATOR HOUSING MAY FILL UP WITH CONDENSATION AND OVERFLOW INTO THE PASSENGER COMPARTMENT, AND INTO THE BLOWER MOTOR THROUGH THE COOLING TUBE. *TT
Service Bulletin Num : 0300014 Date of Bulletin: AUG 01, 2003
NHTSA Item Number: 10003067
Component: OTHER
Summary:
NORMAL NOISE CHARACTERISTICS. *TT
Service Bulletin Num : 03001 Date of Bulletin: JUL 01, 2003
NHTSA Item Number: 10002914
Component: ELECTRICAL SYSTEM
Summary:
OXYGEN SENSOR HARNESS CORROSION - EMISSIONS RECALL. *TT
Service Bulletin Num : 0342B001 Date of Bulletin: JUL 01, 2003
NHTSA Item Number: 10002915
Component: STRUCTURE:BODY
Summary:
WATER ENTRY INTO VEHICLE INTERIOR. *TT
Service Bulletin Num : 0354007 Date of Bulletin: JUN 01, 2003
NHTSA Item Number: 10002027
Component: ELECTRICAL SYSTEM:IGNITION:ANTI-THEFT CONTROLLER
Summary:
IMMOBILIZER SYSTEM INFORMATION UPDATE (2003 MODELS). *TT
Service Bulletin Num : 94 Date of Bulletin: JUN 01, 2003
NHTSA Item Number: 10003756
Component: POWER TRAIN:CLUTCH ASSEMBLY
Summary:
CLUTCH REMOVAL FROM TRANSAXLE. 2003 LANCER EVOLUTION. *TT
Old Mar 24, 2004 | 06:25 PM
smackdaddy's Avatar
Old Mar 24, 2004 | 06:34 PM
augi1's Avatar
Yeah I searched under service bulletins and found it
Old Mar 24, 2004 | 07:15 PM
BaLListic_EVO's Avatar
does this mean???
does this mean i can be expecting mitsu to foot the bill for my clutch when it goes out?
Old Mar 24, 2004 | 07:17 PM
TDC's Avatar
TDC
In Timeout
Re: does this mean???
Thats what Im saying a bulliten is right there its ***d so why do we still have to pay?
Old Mar 24, 2004 | 07:27 PM
yeah for sure... thats some bull****.... They filled me full of some crap about "There was a defect in a batch of clutch disk, if there is damage we will pay but if there is any blueing of the fly wheel you pay for it" I was on the phone with them at the time and they contacted mmusa. At this time my car was 1 week old and the clutch had been slipping just in wot situations... At that time i didnt no let them touch the car. Still havent to this day I even paid for an alignment and tires because of there ****ed up ****ty alignment. But the clutch they may just have to pickup the tab on that.........
Old Mar 25, 2004 | 07:42 AM
Dale_K's Avatar
Seems like every car with a bad clutch disk would have a blued flywheel. You wouldn't know you had a bad clutch until it started slipping and the slipping would cause the flywheel to blue.
Old Mar 25, 2004 | 07:47 AM
TDC's Avatar
TDC
In Timeout
Yes exactly catch 22. Absolute stupidity
Old Mar 25, 2004 | 08:01 AM
ducaticorse's Avatar
mitsu sucks ***. the evo is an under developed piece of ****. i know, i have one. thank you to everyone i've been preaching 2 about the ****ty clutch that came with the car that didn't believe me, next we'll here about the transfer cases. i told you so bastards.
Old Mar 25, 2004 | 08:07 AM
TDC's Avatar
TDC
In Timeout
under developed piece of ****- quite a stretch there. The "Americanized portions" cluth/and tcase yes... the car well watever you think do you complain on the ducati boards about the crap tranny in those wonders?
Old Mar 25, 2004 | 10:43 AM
Secret Chimp's Avatar
Am I missing something absolutely obvious here? I see one bulletin that pertains to the 5th gear grind (5th syncro replacement) and one bulletin that was only to note that there are updated instructions regarding how to remove the clutch from the transaxle.
I see nothing that has anything to do with the clutch. So until there is a bulletin that says "defective prematurely wearing clutches", you will be paying to replace that wear item.
SC~ 27,500 on the original clutch.
Old Mar 25, 2004 | 11:08 AM
Speedlimit's Avatar
Admin Emeritus
Does everyone understand that generates Technical Service Bulletins for Mitsubishi cars, not the government? The NHTSA acts as clearing house for all car manufactures.
And I agree with Secret Chimp, there is nothing implying that the government has even opened a "Defect Investigation". Plus I'm not sure they care if it is not a safety issue.
Speedlimit...
Old Mar 25, 2004 | 06:55 PM
xtnct's Avatar
Service Bulletins are not Recalls. Recalls are the free ones.
Old Mar 25, 2004 | 08:07 PM
articfury's Avatar
A Service Bulletin is free repair if your car exhibits the conditions noted in the bulletin.
I agree with Secret Chimp and Speedlimit about the lack of clutch bulletins.
D
Old Mar 25, 2004 | 08:18 PM
WhosEVO's Avatar
what about the Transfer Case? shouldn't it include at the bulletins a few Evo already have the problem and also replaced by the dealer.
