Need help on what recirculating BOV I should use
Hello guys! I apologies this long question but I rather ask to get this doubt out of the way and I know most of you have been thru this path before and had perform upgrades wisely. So, I have been reading threads regarding BOV wether using a recirculating system of VTA. I got the part down that if my car is not using speed density sensors I will come across a lot of problems because of unmeter air and it could cause surges or running lean or rich if I use VTA blow off valves, is all for sound at this point. I'm not looking for how good sound a BOV makes but rather how efficient an intake system is and how well the performance and gains I could get with bolt ons. I'm currently looking to purchase the ETS short route intake system with a 3" thick intercooler on my evo 9 MR with stock MAF and stock turbo which later I'm going to upgrade. Pretty much the car is 100% stock except for the megan waste gate housing and 3" exhaust. I'm thinking on purchasing GSC s2 cams with GSC beehive valve springs with titanium retainers. While I'm there, I'm going to upgrade my valve stem seals and install ARP head studs. I'm going to upgrade my fuel pump with a walbro 255lph as well as some injectors (1300cc) So, I would like to upgrade my blow off valve from stock and my question is what BOV could I use with this intake system. what would you guys recommend to use without sacrificing performance. Thank you for you help in advance
Believe me your stock valve is good. I personally purchased evo 9 metal valve ( I drive an 8) and it held good 25 psi at wide open throttle spiking 31 psi. No leaks at all. If you want fancy and affordable bov/recirculating valve you can buy Tial QR which I have currently and I'm on speed density. It still makes good sound and not as loud as Q.
I want one that obviously hold boost I, I only run around 30# but it also needs to be sensitive; I dont want an on and off switch. How would you say the 2 compare?
Using my amazing flow chart here, this is how it was connected.
ETS Upper w/Tial flange
TiAL BOV Adapter Flange for SB and DV
Synchronic DV
Rubber hose
Intake
The way the flange connects to the DV, would lead to the DV body cracking. I don't have this issue with the TiAL QR as the connection point is beefier.
Correct.
With the correct spring for the QR, I have absolutely no complaints / noticeable differences between the two products.
As far as the correct spring for the Tial is it one that is included when you buy it or is that a separate piece? I apologize for such newb questions; I admittedly havent read up on DV's in years so its a little rusty. I do recall seeing threads on which port to use and which spring yada yada yada so curious what works best for you.
Im my application it'll see a 30-31# spike which it pretty mild these days. But seems the trick isnt finding a valve that can hold the pressure but rather one that can hold the pressure yet be mild enough in other conditions. Thats what im in the market for...
