Fuel rail with port for fuel press gauge
Old May 9, 2016 | 11:58 PM
asu11's Avatar
What fuel rail is everyone running that has a tap for a fuel press gauge?
Any real differences between the different brands?
I still have stock feed and return lines so one that accepts those fittings is best for me right now.
I also might upgrade to a larger AN feed and return later on so it would also be nice if the rail ends are interchange with AN fittings.
Thanks
Old May 10, 2016 | 11:41 AM
JohnnyTSi's Avatar
Perrin here - works as expected - has a 1/8" npt port for sensor/gauge - works with the OEM fuel line connectors.
John-
Old May 10, 2016 | 09:37 PM
Piro Fyre's Avatar
Radium makes a complete kit with AN fittings and the feed line. You won't have to worry about the feed side when it comes time to upgrade. Just the return side. You can also get the gauge but you'll also need that 8AN ORB to 1/8 NPT fitting with it.
http://www.radiumauto.com/Fuel-Rail-...I-IX-P387.aspx
Apex Hunter
May 21, 2016 06:17 PM
lbcevo
Sep 27, 2011 01:29 PM
Cow
Apr 13, 2011 10:05 PM
D Grade
Northwest Region
Mar 14, 2011 06:02 AM
D Grade
Mar 13, 2011 03:01 PM
