Looking for proper wires for air/fuel gauge and shift light?
Old Mar 29, 2004 | 08:55 AM
MitsuJoe's Avatar
I have used the search and used what I got from it to do what I have done so far. It didn't work!
I am hooking up a Air/Fuel Gauge, and Shift Light which so far don't work as they are suppose to.
For air fuel I tapped into the white wire from the O2 sensor before the connector which is found under the spark plug cover.
As of yet I get no Air/Fuel signal.
For the shift light I tapped into wire #89 on the ECu which is Crankshaft Position Sensor, and the shift light does not work.
Anyone that can point me in the right direction it would be greatly appreciated!
