Valve cover gasket W/ Spark Plug rings ???
Old Aug 30, 2016 | 12:55 PM
Wanted EVO IX's Avatar
Looking for some advise on doing this procedure.
Reason for me to do the swap is I noticed a little oil on my spark plugs when I just changed them a couple days ago. I've planning on doing the gasket swap and the Spark ring seals while I'm at it. I have no visible external leaks what so ever and the car runs great. I don't have a way to do a compression test nor does my car blow any smoke nor burn oil.
Question 1) Do I need to replace the top cover bolts with new bolts before tightening everything up?
Question 2) Is there anything I should know before doing this job? I've read the DIY here on the forum and it looks real easy.
Cheers,
Old Aug 30, 2016 | 01:25 PM
Heres the service manual notes on the removal & installation
Dont think you need to replace the valve cover bolts
Old Aug 30, 2016 | 03:05 PM
barneyb's Avatar
Get too frisky when prying off the cover and buy and new one. Over torque the bolts and buy a new one. Other than that, shake and bake.
Old Sep 2, 2016 | 06:30 AM
Thanks for posting the info, I will use the above to tackle the job.
Cheers
Magrud3r
Sep 25, 2014 06:22 PM
EvoDan2004
Jul 14, 2008 07:23 AM
omniprobe
Mar 25, 2008 07:26 PM
QAT-R
Aug 31, 2006 11:05 PM
