Power question
Old Sep 2, 2016 | 08:05 PM
Bhsj13's Avatar
The BOV should have leaked if they were doing a boost leak test to proper pressures.
true^^ anyway, get a new BOV and retune. all will be good and much more power!
Old Sep 3, 2016 | 01:54 AM
MR. EVO MR's Avatar
That shop sounds like those mother ****ers turbo trix.
Is that shop considered customer or money friendly?
Old Sep 3, 2016 | 08:58 AM
Nadaevo's Avatar
no idea I just know its one of the most reputable shops here in Minnesota.That's why I brought it to them.
Old Sep 4, 2016 | 12:35 PM
Evo__Lee's Avatar
Originally Posted by Nadaevo
so I just got my car tuned from db performance here in Minnesota. It's an Evo 8 2.4l e85 FP black. The car only made 365 and they're saying its because it has a 1g dsm bov on it and the bov is restricting it? Can someone explain from research this build should be 500+.
if I were the shop I would've definitely informed you of the BOV being a factor in your power goals which is of course boost related. If you're looking to run 25+ pounds get yourself a GFB, HKS, or Tial BOV...
Old Sep 7, 2016 | 01:34 PM
Schaphter's Avatar
I believe that the BOV is leaking/not holding boost, You should get a new BOV...
Which BOV do you need?
-It depends the amount of boost that you're going to set. Before buy, check the specs of the BOV, sellers always indicate how much pressure it is able to hold.
Best hopes!
-Hugo
Greetings from Guatemala!
Maximum Output
42
May 24, 2010 11:30 AM
4-BNGR
11
Mar 9, 2006 05:00 PM
AndyC
19
Apr 26, 2005 04:09 PM
JSYEVO
17
Apr 21, 2005 09:44 PM
