Need check valves for twin 450 pump setup?
I have seen some modded oem hangers holding twin 450 pumps and was wondering if anyone is putting check valves in them. I have a check valve in mine and I believe it is causing a flow restriction.
Curious to how cars are running without a check valve installed. Do these pumps with check valves from the manufacturer? I run them staged and the second one is triggered off a hobbs switch.
I maxed my 2150's out (100% IDC)on e81 at 830hp. With twin 450's, -8 feed, -6 return, and a fuellab regulator, this is definitely on the low side.
doncarbone
14
Dec 29, 2014 03:02 PM
FS[Northeast]: Twin 450 fuel pump setups
nwa7265
13
Oct 31, 2014 08:49 PM
GTSMWET
Midwest Region
13
Jul 28, 2005 01:52 PM
