Low idle at stop light. Running lean?
Old Dec 30, 2016 | 09:31 AM
Jovan Caro's Avatar
My evo is running a low idle when I come to a stop died a couple times I had a code that comes and goes It was p0090 just started doing it. my battery was replaced doubt that had anything to do with it and I think it might be running lean at idle cuz of it mods are that came with the car when purchased full uncatted exhaust and greddy boost control and intake filter just need some help were to start looking
Old Dec 30, 2016 | 09:45 AM
Jovan Caro's Avatar
These are my plugs
Old Dec 31, 2016 | 11:46 PM
4b11slayer's Avatar
I think the plugs are too "hot" if im not mistaken there needs to be 3 threads with carbon on em. I only see 1
Old Jan 30, 2017 | 11:19 AM
Fox_IX's Avatar
Heat is best determined by looking where the color changes on the ground strap - in this case it looks Okay but the pic is pretty potato-y.
@OP, check for vacuum leaks, your mods shouldn't be causing lean idle unless you have some cams you didn't know about or something :P
jtbell86
11
Aug 1, 2020 09:23 PM
faviles5566
Mar 11, 2018 01:19 PM
dli03
Apr 23, 2010 06:00 PM
greenemac2003
Aug 2, 2004 07:47 AM
