ACD Problem -- Help!
Old Apr 16, 2017 | 12:17 PM
4G63_Crazy's Avatar
5 Year Member
Hey everyone,
So, today I was out driving my Evo 8 MR, and when I looked down at the ACD lights, all 3 were on (tarmac, gravel, snow). I was looking on other forum pages, saying that it could be because of the weather being too hot or the ATF-SPIII fluid being low. Well, my fluid is on the MAX line, but it is currently 85 degrees were I live. Not sure if that is the issue, or if there is something else that is wrong. Any help would be appreciated! Thanks
Old Apr 16, 2017 | 12:59 PM
4G63_EVO's Avatar
it shouldnt be from that temp. Check your Fuse link on the battery, I blew mine out on mistake once and it caused the 3 light fault code. Ended up being that
Old Apr 17, 2017 | 01:49 PM
heel2toe's Avatar
Chances are your pump is on its last legs and will need to be rebuilt/ replaced.
Old Apr 17, 2017 | 05:57 PM
4G63_Crazy's Avatar
5 Year Member
Ok, now for some strange reason the lights aren't coming on anymore... Maybe it is an electrical issue somewhere...
Old Apr 17, 2017 | 07:16 PM
heel2toe's Avatar
Yep thats how it goes your pump is toast. Mine did the same thing and the three lights wouldnt always come on but would do so more with extended drives, sitting stationary and during auto-x it was consistent after the first run so I do believe there is some correlation between heat and the three lights.
Old Apr 18, 2017 | 04:51 AM
kikiturbo's Avatar
pumps corrode which leads to increasing tolerances in the pump... as a result of this when the weather is a bit warmer it will start failing..
Old Apr 18, 2017 | 07:22 AM
kyoo's Avatar
glad I don't daily my evo or drive it in the salt
Old Apr 18, 2017 | 08:08 AM
heel2toe's Avatar
^What he said he's the ACD wizard!
Lol yeah yeah. Eva should be retired from snow duties now so I think Im good to go
Old Apr 18, 2017 | 12:25 PM
kikiturbo's Avatar
but evo's are best in snow..
even the corroded fuel tank top is worth it...
Old Apr 19, 2017 | 05:33 AM
4G63_Crazy's Avatar
5 Year Member
This car was originally from New York State and lived on a top of a mountain where it snowed... So, yea, The salt most likely corroded it over the years... It already corroded the underneath... Rust galore.... Sadly.
Old Apr 19, 2017 | 07:47 AM
heel2toe's Avatar
Yeah its a blast in the snow but my seized LCA bolt that I dealt with years ago sucked. And funny you mention the gas tank. Thankfully mine last time I pulled the pump was still fine but we were putting a wally in my friend's evo a year or so ago and a few of the studs snapped which meant tank had to be dropped. Talk about a giant PITA for something that should have been a 15 minute swap. Oh and of course my corroded pump was a good time...
Yeah like we said your pump is toast. See if you can find a suitable replacement pump or pickup a rebuld kit and pull it apart. Good luck!
06MREvo
For Sale - Part Outs
34
Nov 18, 2014 01:05 PM
NOMIEZVR4
Oct 18, 2013 01:28 PM
DubsE46
Sep 11, 2012 12:03 AM
DubsE46
10
Dec 30, 2011 04:48 PM
