Evo 8 iacv & idle question
Old Jul 22, 2017 | 08:13 PM
2006EvoIXer's Avatar
Originally Posted by Evolved25
Correct the factory wastegate solenoid is leaking. That's why I was asking about using a MBC in place of it.
Try connecting the hose from turbo to wastegate actuator like Biggiesacks suggested to see if your problem is solved. If that solves your problem, I have my stock boost controller and I'll be in Vegas in about 6 weeks. I think the 9 uses the same controller as 8.
Old Jul 25, 2017 | 04:09 PM
Evolved25's Avatar
i will try this and report back
Old Jul 25, 2017 | 05:39 PM
Evolved25's Avatar
So put a capped vacuum t in place of the factory wastegate solenoid and no change in idle. Sprayed carb cleaner on ic piping connections, throttle body, intake manifold and injector isolators and no change in idle. Got an eBay iacv and tested that and same result. May need to look into getting a tactrix cable and verify that the car has a stock map, running out of ideas.
Old Jul 26, 2017 | 09:27 AM
Your leaks have to be fixed. I don't see how leaks before throttlebody affects idle, but I can see that making car run richer AFRs. Leaks at and after throttlebody will cause high idle. Try capping all the vacuum lines on intake manifold to see if idle drops. If it does, then reconnect one at a time to find leak. If idle stays high, I'm thinking it something mechanical like IAC or tune.
I have cable to look at ecu map if you know how to use it, but I won't be in Vegas until night of September 8.
Old Jul 26, 2017 | 10:03 AM
stvn87903's Avatar
Another thing that could cause some issues (probably not the main solution) is the BISS screw itself. It's made of plastic can erode / burn up over time. I've seen pictures on here of some that look pretty burnt up from detonation / back fire issues. I think they're only a couple dollars new anyways.
Old Jul 26, 2017 | 10:02 PM
Evolved25's Avatar
BISS was replaced when I installed works throttle body shaft seals, when I used my snap on modis to lock the iacv motor for adjustment it idles perfectly stable at 1k, issue arises when I unlock the iacv motor.
I went a got a bunch of vacuum vacuum caps and will cap all the ports on IM and resort back thanks for all the suggestions guys!
Old Aug 1, 2017 | 08:17 PM
Evolved25's Avatar
So to keep this updated:
Capped IM with vac caps and idle is still the same, tested with 2 iacv motors and issue is still there. Plan is to purchase a tactrix cable in the next week or two and checking tune, will keep you guys updated.
Old Aug 2, 2017 | 09:29 AM
Sounds like only the tune is left.
Old Aug 2, 2017 | 09:47 AM
deylag's Avatar
Yea pull the rom from the ecu and check how many steps the IACV is running at idle. Most likely it has been changed to compensate for all the issues it had before.
Old Aug 7, 2017 | 09:17 PM
Evolved25's Avatar
Update and fixed!
So had a local tuner come over today to pull the rom and low and behold warm idle was set at 1300 rpm with timing set to 10* at idle. Had him upload a factory map in and idle is now running at 850. Wish I would have checked this a long time ago but fixed a lot of underlying issues that would have caused me woes down the road. Long story short; Check the basics first!
Thanks for the help along the way I hope someone else can benefit from my experience and at least point them in the right direction to solving their own issues!
Old Aug 8, 2017 | 09:09 AM
Awesome! 👍
Update and fixed!
Old Aug 8, 2017 | 09:15 AM
If you did, you wouldn't have found your boost leak in your solenoid that could potentially cause your turbo to run harder to push higher than stock boost.
Old Aug 8, 2017 | 12:47 PM
Evolved25's Avatar
100% correct about that, there are definitely benefits to having gone through everything just felt like I was beating a dead horse hah. Either way glad its fixed now
iLLevo_
Jan 25, 2017 03:34 PM
NattyMyst1c
Apr 11, 2012 11:46 PM
hyeteck
Sep 10, 2011 07:39 PM
korndogg
Apr 9, 2010 08:10 PM
